boost leak???
Old Oct 10, 2009 | 01:11 PM
KiltEmWhooptem's Avatar
Default boost leak???
ok i put my injection pump on the other day and when i pulled my intake horn off i ripped one of the gaskets so i put it on just to test drive it and it was makeing a whistle noise that came on when i was makeing some boost so i put and new gasket on it and it now sounds like a loud breathing noise. what could this be everything is tight and i dont see any rips in the boots
Old Oct 10, 2009 | 01:14 PM
12vcummins96's Avatar
when you drive what are your boost levels the boot might not be on right intake could be warped ar u having a power loss
Old Oct 10, 2009 | 01:21 PM
yea im not seeing the same boost at all.
Old Oct 10, 2009 | 01:24 PM
okay retorque all your bolts check you boots real good you might have torn the boot pullin on it but cant see it
Old Oct 10, 2009 | 01:25 PM
im going to put soap water on it while some one spools it that will find the leak.
Old Oct 10, 2009 | 01:38 PM
yeah that will work let me know what you find
Old Oct 11, 2009 | 11:55 AM
ok figured out what it was. when i put my airdog on i took off my stock fuel filter and forgot to put the bolts back in and blew intake cover gasket.
Old Oct 11, 2009 | 11:59 AM
well i am glad you found the boost leak it sux that it was that though
Old Oct 11, 2009 | 12:09 PM
mysterync's Avatar
Common problem! I've fixed the exact same problem about 15 times in 3 months, Make sure you use a shorter bolt where your fuel filter housing was (not the stock bolts)
Old Jan 10, 2013 | 11:17 PM
cummins24valve's Avatar
That's weird I just did the same thing when I did injectors and it was one bolt drivers side front she was leaking like crazy I tightened the bolt and tested to 30 psi not a single bubble I may have gotten lucky but with my mileage at 15 city I knew something was wrong hoping I see a nice gain in mpg I already noticed the gain in power
InheritedDiesel
Jun 3, 2015 09:39 PM
stewart.william.c
Feb 11, 2015 01:39 AM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
joshkhouse80
Nov 21, 2014 01:17 AM
