3gsk how to install?
Old Oct 10, 2009 | 12:41 PM
rollincoal12valve's Avatar
Default 3gsk how to install?
can anybody tell me what i have to do to put these in i cant find an install thread
Old Oct 10, 2009 | 12:56 PM
12vcummins96's Avatar
on the side of the pump there is a 7/8 plug next to the throttle lever remove that plug turn the motor clockwise until the spring coms to the top mark where the nut is and how many turns down to make sure you get it back in the same place remove the nut use a magnet to gather the parts and shims ect leave the largest spring but remove all the rest springs use the springs supplied in the kit with the other large spring and put back together then turn the motor over until other spring shows up hope this helps you
Old Oct 10, 2009 | 01:03 PM
thank you so much it doesnt seem to be to hard but i guess we will find out
any clues on why i have no overdrive?
Old Oct 10, 2009 | 01:09 PM
check your fuses and relays whats the color of the fluid any change when you push the od button will the conveter lock up
Old Oct 10, 2009 | 01:11 PM
i checked the fuses and relays and i just put more fluid in it a week or so ago and yes when you put overdrive off it will lock up
my truck will only do 70mph at wot
Old Oct 10, 2009 | 01:34 PM
was the fluid burnt brown how low was it
Old Oct 10, 2009 | 01:40 PM
it was empty and i have to check it again to see the color
Old Oct 10, 2009 | 01:43 PM
it sounds like you od unit is burned up
Old Oct 10, 2009 | 02:26 PM
how do i change it or fix it and what kind of money am i looking at?
450r racer
8
Dec 21, 2015 06:42 PM
lkfldredneck
Jun 25, 2015 04:51 PM
turbodieselman
Mar 14, 2015 09:19 AM
Gman30
Dec 27, 2014 12:46 PM
Cody Cain
Dec 22, 2014 01:27 PM
