code po206
Old Oct 9, 2009 | 08:13 PM
redfor78's Avatar
Default code po206
2007 dodge ram 2500 cummins 5.9 gettin injector circut #6 code po206. What could this be the wiring under the valve cover or the actual injector. the dealer has it now but they said cuase i have the edge box on it that it it is the injector that failed it might not be covered. the want 1200 for one injector, thats bull$hit. if thats the case ill buy new set of 6 aftermarket 50hp ones. but i hope its just the wiring. Any feedback?
Old Oct 9, 2009 | 08:19 PM
wildbill's Avatar
PASS TROUGH CONNECTORS OPEN
FUEL INJECTOR
INJECTOR HARNESS OPEN
HIGH SIDE DRIVER HARNESS OPEN
LOW SIDE DRIVER HARNESS OPEN
ECM
Old Oct 9, 2009 | 08:21 PM
wildbill's Avatar
BTW, I had all 6 injectors and tubes + labor, and it only ran me $4000. Which in turn equals only $650/injector. I think they are trying to rake you over the coals.
Old Oct 9, 2009 | 08:42 PM
redfor78's Avatar
what do you think could be the issue
Old Oct 9, 2009 | 08:46 PM
wildbill's Avatar
What kind of Edge box is it, EZ or Juice??
Old Oct 10, 2009 | 08:16 AM
cerberus60's Avatar
The $1200 could be one of the new stainless steel body injectors also. Need to clarify that with them.
The usual cause is a bad solenoid on the injector, but, a bad connection or VC gasket wire can also cause it. There is a set of test procedures detailed in the FSM to trouble shoot it and the dealer needs to run those tests to verify. Occasionally its a bad harness connector that is causing it.
If you have a box that is tapping into the injector harness it could be the box also. Need to remove it first and check for the same codes. The Edge boxes are a bit notorious for causing issues when they are not quite right.
dwmeehan
Sep 6, 2015 04:20 PM
Saams69
Jul 20, 2015 11:21 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Backhoeman
Jan 3, 2015 12:53 PM
