M2 fuel pin update
Old Oct 9, 2009 | 07:38 PM
Richie O's Avatar
Default M2 fuel pin update
First of all I would like to thank M+H and this site for the free fuel pin.
Here is what I found.
My truck has the following mods. 6x16 injectors, H1C with a 16 cm exhaust and 60mm GDS upgrade, star wheel way up from stock ( to help with low boost smoke ), fuel pin turned to deepest, fuel screw 2 full turns out from bottom, piston lift pump. At those settings I maxed out at 43 to 44 psi in 5th gear wide open. I put the pin in and changed nothing else. I saw a peek psi of about 49 to 50 psi. So I can basically say the pin gave me about 6 psi. My plans are to turn my fuel screw so my max boost is back to 42 psi ( as I still have a stock head gasket ). That should get rid of some more of my low boost smoke as well as give me around 30 psi at max throttle with valet in tow mode.
Old Oct 9, 2009 | 07:53 PM
RSWORDS's Avatar
AWESOME!!! Glad you got it for teh dyno day!
Did the old set the pants dyno net you any gains? Does teh power come on sooner over the stocker?
Old Oct 9, 2009 | 08:11 PM
Richie O's Avatar
Well bobby, I saw the gauge go to 50 psi and I let off. I did that once and will now turn the fuel screw down to get back to 42 or so. I do not want to pop the head gasket.
It had to give me more power as the boost was up.
Old Oct 9, 2009 | 08:16 PM
RSWORDS's Avatar
HG's are easy to replace!
Old Oct 9, 2009 | 09:56 PM
tower_ofpower's Avatar
says the man runnin a silver 62 waiting for his to let loose
great update richie, they got that shipped to you lickity split. that's customer service for ya
Old Oct 10, 2009 | 12:19 AM
Alwaysworking's Avatar
i was wondering how it was working for you, sounds good.
Old Oct 10, 2009 | 01:50 PM
RSWORDS's Avatar
Originally Posted by tower_ofpower
says the man runnin a silver 62, 82 jet of Nitrous, and 60+ psi of boost, waiting for his to let loose, again
Fixed it for you!
A head gasket is only a saturday worth of work!
Old Oct 10, 2009 | 03:07 PM
Richie O's Avatar
Well today I got to play with the fuel screw. As I said above I was happy with the boost I had with the stock pin, 42 to 44 psi , but was unhappy with the bottom end. I took 1 full turn out of the fuel screw and went for a ride. At wide open in 5th the boost was back down to 44 psi, perfect I also hoped that when I took the full turn out it would help my haze issue. ( pretty hazzy all times at speed and idle ). It took about 75 percent of the haze and low boost smoke. It does take a little longer to spool the turbo until the afc ( pin ) drops into the deep side then its game on. As soon as I get my valet set up ( still need to buy ) I will be able to tow with the ole girl with out watching the egt's so close. So in conclusion, the M2 pin did what I wanted.
1 Keep my boost at 44 psi while at the same time take 1 turn off the fuel screw.
2 Took away lots of low boost smoke and haze. ( because I was able to take out the turn )
3 Will work great with a valet.
So in my case I used it as a tunning feature to help make my 6x16's more streetable.
Old Oct 10, 2009 | 09:05 PM
RSWORDS's Avatar
Hell yeah!!!
Not to hyjack but I pushed teh pump to teh head today and it took away my haze with teh 6x16's... Just a thought...
Old Oct 11, 2009 | 02:00 AM
Fixed it for you!
hahaha thanks for that bobby; dont want me to look like a liar or anything
Hell yeah!!!
timings good... timing is ALWAYS good... when ever i bumped mine up the truck stayed pretty quiet for awhile as in no diesel knock at all ran an *** load of injector cleaner thru it on my way to VA crankin about 75mph and what i now know was 25-2600 rpm... made the trip home and after that talk about a sweet diesel sound man... years of neglect must have gunked everythin up b/c her lungs sure are clear now
Last edited by tower_ofpower; Oct 11, 2009 at 02:00 AM. Reason: Automerged Doublepost
