Tranny Fluid and engine oil change
Old Oct 8, 2009 | 08:01 PM
tdiezel's Avatar
Default Tranny Fluid and engine oil change
Well I am discovering I love being a DIY-er! I have a few questions though. I know how to change the engine oil and am going to convert over to AMSOIL when I do here in the next couple of days but I also want to change the tranny fluid and eventually the differential oil to see if I cant get some better gas milage and get my truck to run a little better. My questions are, Can the tranny being low on oil or having old oil make it more difficult to shift into gear? Can I change the tranny fluid myself? Do I need to do some sort of flush to clean out the old fluid in the tranny, and finally, Where do you put the tranny fluid in? Thanks for all the help!
Old Oct 8, 2009 | 08:06 PM
wildbill's Avatar
Yes you can change the fluid yourself. You running an auto or manual??
Old Oct 8, 2009 | 10:01 PM
handymanherb's Avatar
Banned
If your realy want to like doing oil changes get one of these from Geno's http://www.genosgarage.com/prodinfo....er=FTP-F104N-A, I can do a oil change after pulling in hot with no tools needed and be done in 10 minutes if need be
Old Oct 8, 2009 | 10:13 PM
wildbill's Avatar
Yeah, but you have to remove to get all the oil out.
Old Oct 8, 2009 | 10:20 PM
tdiezel's Avatar
I have a 6spd manual transmission. I ordered all the oil from Heath and it should be here tomorrow.
Old Oct 8, 2009 | 10:22 PM
wildbill's Avatar
G-56 STANDARD PROCEDURE
DRAIN AND FILL
1. Raise and support vehicle.
2. Remove drain plug (1) on transmission (2) and
drain fluid.
3. Install drain plug and tighten to 57 N·m (42 ft. lbs.).
4. Remove fill plug (1) on right side of the transmission
(2).
5. Fill transmission even with the bottom of the fill
hole.
6. Install fill plug and tighten to 57 N·m (42 ft. lbs.).
Getrag 238 STANDARD PROCEDURE
DRAIN AND FILL
drain fluid.
3. Install drain plug and tighten to 50 N·m (37 ft. lbs.).
4. Remove fill plug (1) from side of transmission (2).
hole.
6. Install fill plug and tighten to 50 N·m (37 ft. lbs.).
Old Oct 8, 2009 | 11:39 PM
tdiezel's Avatar
I have a NV5600 though. Im pretty sure. I think..... Will it still be the same principle anyways?
Old Oct 8, 2009 | 11:42 PM
wildbill's Avatar
T56 STANDARD PROCEDURE - DRAIN AND FILL
2. Remove drain plug (1) on transmission tail housing
and drain fluid.
3. Install drain plug and tighten to 38 N·m (28 ft. lbs.).
4. Remove transmission fill plug on left side of the
transmission case.
5. Fill transmission to bottom of the fill hole.
6. Install transmission fill plug and tighten to 27 N·m
(20 ft. lbs.).
Old Oct 9, 2009 | 12:11 AM
tdiezel's Avatar
Hahaha awesome thanks bill!! Should be a piece o'cake! You had me questioning If I knew anything about my tranny or not .
vin_diesel
Mar 1, 2016 01:43 PM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
LTreis702
Feb 14, 2015 12:52 PM
