vp44 bracket
Old Oct 8, 2009 | 04:29 PM
KiltEmWhooptem's Avatar
Default vp44 bracket
well i got my pump off today and i noticed that my rear bracket wasnt the same as the others i have seen. my bracket has 4 bolt holes and only 3 are used the other has no point, 2 of them go into the bottom of the vp and the other one gos on a metal rod that comes up from the frame and bolts in there never seen this kind of bracket, has anyone else ever had one of these?
Old Oct 8, 2009 | 04:55 PM
mysterync's Avatar
I'd have to see a picture to grasp my mind around your description
Old Oct 8, 2009 | 05:48 PM
ok here is a pic of it
http://i857.photobucket.com/albums/a...tem123/123.jpg
Old Oct 8, 2009 | 05:59 PM
mysterync's Avatar
It's a factory style bracket. They actully used a few diffrent styles you'll see from time to time. Without support , under load the pump could break free of the housing.....that would be bad
Make sure you put it back on!!
Old Oct 8, 2009 | 06:27 PM
why does it have a bolt hole that didnt have a bolt in it or anywhere to boltit up to? its that peice that sticks up it the pic
Old Oct 27, 2009 | 04:01 PM
greasemonkey's Avatar
Originally Posted by KiltEmWhooptem
I'm swapping the short block in our '00 work truck and this bracket is missing. I swear I saw it when I took the other engine apart but now I can't find it anywhere...
I read on another forum that Dodge/Cummins updated this bracket because the early style would break and eventually crack the timing case, too. Both options sound bad.
Old Oct 27, 2009 | 04:11 PM
Uncle Bubba's Avatar
Ya ya just don't hear about the bad brackets anymore cause most all of them on the road have already been replaced or have broken and then replaced already.
justinsbeck
Jan 18, 2016 12:15 AM
tbreddiesel
Contests And Give Aways
Aug 14, 2015 02:47 PM
tbreddiesel
Jul 30, 2015 09:13 AM
tbreddiesel
Jul 21, 2015 07:28 AM
somarillw
Dec 15, 2014 12:00 AM
