05 dodge starting problem
Old Oct 8, 2009 | 02:43 PM
splints's Avatar
Default 05 dodge starting problem
my 05 needed the fuel filter changed so i changed it but not before it decided not to start the other morning i drove it 2 mi came home- next day it wouldn't start - pulled the fuel filter made sure the "o" ring was good cranked it up -- next day same thing bled the filter with the bleeder --- today same thing wont start got it started put 60 mile on it ran fine ----any ideas??: argh:
Old Oct 8, 2009 | 03:01 PM
wildbill's Avatar
It had the starting issue before the filter change?? Then the same thing after wards?? Does it have the fuel pump in the tank or on the engine??
Old Oct 8, 2009 | 03:08 PM
tdiezel's Avatar
May be a lift pump starting to go out.
Old Oct 8, 2009 | 03:16 PM
staarma's Avatar
05's are in the tank. There was a TSB for hard start on the 05's but I forgot what it was. I'll try to find it. The other thing is the lift pump like said above.
Edit:
I think this is it. http://dodgeram.info/tsb/2006/14-003-06.htm
Old Oct 10, 2009 | 12:35 PM
splints's Avatar
Default 05 starting problems
Thanks Guys,
Your replies are invaluable set me on the right track . Now looking for an alternative to the in-tank will let you know how i make out.
Old Oct 10, 2009 | 02:13 PM
skinnysfd's Avatar
get an air dog or fass
burndiesel
10
Feb 7, 2023 01:15 AM
rschriek
Feb 3, 2015 10:13 AM
Dec 12, 2014 12:30 PM
Nov 3, 2014 08:10 AM
Jmohr52
Nov 2, 2014 08:55 PM
