injector problems
Old Oct 7, 2009 | 11:35 PM
navalseabee's Avatar
Default injector problems
ok so whats the permante fix for the duramax injector problems..... and how hard would it be put the injectors in myself.....and along the same lines what in you opinion would be the best programmer or chip for towing. my friend has a 03 that pulls a 40ft toy hauler. thanks guys
Old Oct 7, 2009 | 11:39 PM
2500HeavyDuty's Avatar
buy some NEW ones from the dealer or a trusted shop.
heres some threads that would help you out with the injector swaps if your going to tackle the task.
https://www.dieselbombers.com/lb7-bo...ips-hints.html
https://www.dieselbombers.com/chevy-...r-sleeves.html
Old Oct 7, 2009 | 11:59 PM
would the total new ones from industrial injection work, or how about just the nozzles from ddp or someone do the trick....and what exactly is the problem with the injectors.??
Old Oct 8, 2009 | 01:44 AM
yes the ones from industrial injection would work, and they come with a one year warrenty too i believe. nozzles wont fix the injector, the body goes bad.
i dont know what goes wrong with them, theres hundreds of pages discussing what goes wrong and what the fix was over from 04.5 with the lly motor, but not everyone is 100% sure what kills them theres alot of opionions on what does the injector in.
Old Oct 8, 2009 | 01:46 AM
12vcummins96's Avatar
also if you do put upgraded injectors get some guages first
