Injectors
Old Oct 7, 2009 | 04:11 PM
ffemt44169's Avatar
Default Injectors
Hey, I have a 2002 Dodge Dually with the 5.9 HO Cummins, I have 4" MBRP exaust K&N filter, and Superchips stage 3 programing. I am now looking to upgrade injectors. What stage injector should I go with.
Old Oct 7, 2009 | 04:14 PM
Wyatt Earp's Avatar
Do you have any plans on getting twins or a different / larger single? If so, anything, if not stage 3 at the most.
Old Oct 7, 2009 | 06:53 PM
ffemt44169's Avatar
I don't have any plans in the near future of turbo upgrade. Will it somke like a freight train if i go up to a 3 without increasing air? or will it be fine
Old Oct 7, 2009 | 06:55 PM
12vcummins96's Avatar
it will smoke but with smoke comes heat and that is bad make sure u have guages
Old Oct 7, 2009 | 07:30 PM
ffemt44169's Avatar
without gauges, what stage? I dont want to damage my engine. Whats the biggest I can safely go
And I do not want smoking unless im in the throttle hard
Old Oct 7, 2009 | 07:47 PM
NCFPD's Avatar
Default l
hey personaly if you go with anything extra that inhances power i would ave gauges just to be safe and it keeps you up on what your trucks doing and how its performing but thats my opinion
Old Oct 7, 2009 | 09:52 PM
01quadcab's Avatar
you need gauges on a stock truck as the fuel pressure could be low and you will need a new injection pump. ditch the superchip and get a good programmer and you will not need gauges you can do them at a later date
Old Oct 7, 2009 | 11:31 PM
gpandlf's Avatar
exactly , and spend your money on a good lift pump first, my first injectors were 110's the only issue I had was my tranny went out, egt's were ok , smoked but only when I wanted it to, I actually sold my old ones to my buddy with basically the same set up you have now, except he has the edge ez, he pulls a lot he has no issues with smoke or egts and loves the power, but I wouldn't go any higher than 110's if you don't want a turbo upgrade.....
Old Oct 8, 2009 | 07:37 AM
auto2010's Avatar
like everyone has said, you NEED gauges, the last thing you want is t obe overheating and melt a piston because, as hotcummins said, with smoke comes heat...
Old Oct 8, 2009 | 09:10 AM
biged681985's Avatar
with rv injectors and nothing else, i could hit 1350 on the floor hard. which is to hot for a sustained amount of time. with the super chips, i figure u will have higher egts with just a 40hp injector. u need some gauges before u do injectors. jmo good luck
