more fuel at WOT
Old Oct 6, 2009 | 04:03 PM
cumminscraz's Avatar
Default more fuel at WOT
Hey guys, has anyone used a 2nd gen lift pump and a pressure regulator after the filter to maintain a constant fuel pressure at, say, 15 to 18 psi? Right now at 3/4throttle my pressure
stays at 16, at WOT it drops to 0
Old Oct 6, 2009 | 05:39 PM
RSWORDS's Avatar
Yes. You can get a low pressure piston lift pump that will be set at the correct PSI and not need the regulator.
Here are the parts you need and the part numbers
Your going the need to trim the insulation off th eside the block to make it fit.
Old Oct 6, 2009 | 06:33 PM
I've got that pump already but seem to be loosing my pressure across the filter. I am putting a stock filter from a 2nd gen on later this week, but am sort of pesemistic about
the result. Hope it's ok but would like a "PLAN B" Sorry, I did't mention the pump in my sig.
Old Oct 7, 2009 | 04:29 PM
RSWORDS's Avatar
with tha pump (check the part number) you dont need a pressure regulator. It wont make too much pressue. You fuel pressure dropping to 0 is most lickly from the small *** stock lines. Replace them with some 3/8" line and see were you are.
Old Oct 8, 2009 | 01:55 AM
big bad diesel 416's Avatar
Site Sponsor
can a guy run barbed fitings and some 3/8 soft fule line from lift pumt to filter to dist pump? or will 15psi burst it?
i aint too big of fan of those banso bolt things...yuk
Old Oct 8, 2009 | 01:58 AM
12vcummins96's Avatar
no 15psi wont burst it just make sure it is diesel approved line diesel will eat up rubber after a while
Old Oct 8, 2009 | 02:00 AM
Site Sponsor
how do i tell?
Old Oct 8, 2009 | 03:51 PM
tower_ofpower's Avatar
Originally Posted by big bad diesel 416
how do i tell?
dont go to advance auto; thats one way to tell . search for an industrial hose supply place i can almost garuntee they'll have it. also if you have a less commercialized parts place like carquest around they should be able to hook you up
Old Oct 8, 2009 | 09:20 PM
Thanks guys,
I'll try the filter first and go from there. That will be the cheapest, then upgrading the feed line,last a high pressure lift pump and a pressure regulator
Old Oct 14, 2009 | 07:25 AM
1stgenjunkie's Avatar
It will take a little extra money or some hard looking, but what I did was use a second gen pump but put the low pressure spring in it. The second gen pump has a bigger piston bore in it were as the the low pressure unit has a smaller bore and piston. So in thery u would have the best of both worlds high volume at a low pressure. My fuel pressure stays at a constant 16psi weither at idle or WOT. Also I used all 1/2" lines, Made a draw straw for the tank, and bought the fitting from vulcan that goes into the injection pump to connect 1/2" fuel hose. Do that stuff and no more fuel starving issues! Hope this helps!
