fuel shut off solenoid
Old Oct 5, 2009 | 08:03 PM
cumminskid92's Avatar
Default fuel shut off solenoid
is it possible for the solenoid to get stuck open. when i turn off my key it does absolutely nothing and my truck keeps running . i checked to make sure it was killing the power when i turned the key off and it is. thanks for any help
Old Oct 5, 2009 | 10:14 PM
tower_ofpower's Avatar
i imagine so; guessing by your name the truck is a 92'... and i also assume (since you dont have your sig filled out) that you've been tweakin the pump... i've read that the intercooled engines have problems with the shut off solenoid when pump mods have been done... atleast until a larger set of injectors are installed. most guys take the solenoid out; remove the plunger and re-install the solenoid then use the manual shot off on the side of the pump from then on.
Old Oct 5, 2009 | 10:20 PM
Begle1's Avatar
The rubber tip on the plunger is a lot more likely to shred off than get stuck in the "up" position, especially on a turned-up truck, especially when that truck is an intercooled truck with stock injectors.
Until you replace der ELAB use der shut off lever on the side of der pump.
Old Oct 6, 2009 | 09:59 PM
i didn know about the shut off lever on the pump. can you give me any more information about it
Old Oct 7, 2009 | 11:02 AM
Begle1's Avatar
It's the lever on the side of the pump that turns off the truck when you pull on it. You can run it to a pull cable to shut the truck off without the key.
Old Oct 7, 2009 | 01:20 PM
cant get too much clearer than what begle had said. its directly below the AFC housing cant really miss it
Old Oct 7, 2009 | 02:27 PM
TTipsword's Avatar
yup what he said. just start pullin on things that look like a lever until your truck shuts off!
camp9
Mar 25, 2017 07:40 AM
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
