01 Dodge 3500 Auto Tranny Problems
Old Oct 5, 2009 | 02:39 PM
drsanford's Avatar
Default 01 Dodge 3500 Auto Tranny Problems
I've got an 01 Dodge with a rebuilt auto tranny, with only 3000 miles on it, and it just started bouncing between 3rd and OD.
At 50 mph the tranny can't decide if it wants to run in OD or 3rd and keeps shifting up and down.
Any ideas?
Thanks
Old Oct 5, 2009 | 02:44 PM
12vcummins96's Avatar
needs a tps
Old Oct 5, 2009 | 02:50 PM
mysterync's Avatar
Most times this can be fixed with a inline noise filter. But it could also be internal transmission issues. It's hard for me to diagnose from here but I would start with a noise filter!
Old Oct 5, 2009 | 04:26 PM
SCox's Avatar
Ground the apps ground wire, black with yellow trace. Use solder and heat shrink, extend to the battery from the apps and the pcm and that should fix it. Worked like a charm on mine. Try the free things first!
Old Oct 5, 2009 | 04:35 PM
drsanford's Avatar
Ok man, what is the apps?
And what is the pcm?
Thanks!!!!!!!!!!!!
Old Oct 5, 2009 | 07:43 PM
turbo20psi's Avatar
Accelerator Pedal Position Sensor (APPS)These truck do not have throttle cables they use sensors to determine throttle postion.The pcm is Powertrain Control Modules (PCM)
this located on the passenger side of the truck.The problem is that your touque convertor is locking and unlocking this is done electronicly by the pcm.This is caused by electricial interference from the alternator.To fix this there is a black with a yellow tracer wire that comes from the apps sensor to the pcm you cut this wire and run it to the negetive side of your battery.While you are do that clean all your battery terminals to,check your grounds(black wire) on the block for cleaniess and tightness.Hope this helps.This seems to be a common problem on these trucks.
Old Oct 5, 2009 | 07:46 PM
mysterync's Avatar
Better termed, While the truck has a throttle cable, The fuel control is done by the APPS sensor. A true fly by wire system is like a 7.3L with the TPS under the pedal.
Old Oct 5, 2009 | 08:58 PM
turbo20psi's Avatar
Sorry had the BMW on my mind.no cable there true like the 7.3.thanks for the correction.
Old Oct 5, 2009 | 09:12 PM
scottsjeeprolet's Avatar
Go RAVENS!!!!!!!!!
Only 3000 miles. Take it back to whom ever fixed it and get them to fix it again under warranty.
Old Oct 8, 2009 | 07:10 AM
drsanford's Avatar
Thanks for the input man!!!!!!!!!
Man I got the tranny rebuilt, tok a long trip and didn't get the tranny checked in the 1st 1000 miles and voided the frigging warranty.
The pits
Jet A Fuel
For Sale
Aug 16, 2015 04:44 AM
peterbilt
Chevy/GMC Duramax 06-07 LBZ
Apr 8, 2015 10:33 AM
Ol Goat
Jan 22, 2015 02:16 AM
TNTPrime
Jan 5, 2015 06:13 PM
Tucker126
Jan 2, 2015 08:09 AM
