intake grid heater question
Old Oct 4, 2009 | 11:22 PM
tltruckparts's Avatar
Default intake grid heater question
my 93 the intake heater isnt working correctly it isnt metering out right. i cant find an intake heater for the first gens. my question is are the second and third gens the same intake heater? i dont see how they would differ i believe there all the same size. so if i find one off of a 24v would it work? any input is appreciated. thanks
Old Oct 4, 2009 | 11:31 PM
tower_ofpower's Avatar
what part isnt metering out right? bobby has graciously supplied us with a description of operation and a general diagnostic proceedure for the grid system. it says your supposed to have 0 ohm of resistance across the grid from chasis ground to the 12v supply... 0 ohms is great but it also sounds abit low in resistance, to me i figure it'd draw too much amperage and pop the fusible links especially if it end up pre-heating for 20 seconds. that's full amperage being drawn, similar to crossing the battery terminals doesnt really seem to equal out but i guess if it works; it works
Old Oct 4, 2009 | 11:38 PM
were only getting one side of the two terminals to supply power i dont remember exactly what was wrong i just know my electrical guy said it wasnt working correctly and only half of it was working. and the single terminal side where it grounds out is all stripped from the previous owner i cant get it on or off its busted, so i just want to get a new one and start over
Old Oct 4, 2009 | 11:40 PM
if only one side is gettin source voltage then i'd look into either the supply to the relay, a relay or the control circuit for that relay
Old Oct 5, 2009 | 12:03 AM
everything works correctly its all been tested i know as i fact i need a new intake heater. just wondering if one off of a different engine will work or not
Old Oct 5, 2009 | 12:21 AM
big bad diesel 416's Avatar
Site Sponsor
you pay the shipping and i will give you everything except the little block on the manafold
i gutted mine have everything in a bag took the thing on the fenderwell off all you need to do is connect the wires and put my grids in your block
Old Oct 5, 2009 | 12:31 AM
greasemonkey's Avatar
I don't know about the 3rd gen ones but the 2nd and 1st gens seem to be the same. I'm referencing that from the work I've done on the two 1st and two 2nd gen trucks at my work.
Old Oct 5, 2009 | 12:33 AM
what do you mean by the little block on the manifold? are you talking about this:
00 Dodge Cummins turbo diesel INTAKE HEATER GRID:eBay Motors (item 360194656839 end time Oct-06-09 19:00:07 PDT)
thats the piece that i am after. the actual heater itself
Old Oct 5, 2009 | 12:45 AM
Site Sponsor
best i can do here
Attached Thumbnails intake grid heater question-bbu2l-bgk-kgrhquh-c0equdlqdkwbk-v6e8fiq-_35.jpg
Old Oct 5, 2009 | 12:58 AM
best i can do here
your hell of a sales man "i keep this, but you can have all of the x's" i bet you sign your name pretty well on those electronic signatures there at wal mart too dont ya?
