Mod recommendation- blank canvas
Old Oct 4, 2009 | 09:43 PM
BADMUDR's Avatar
Default Mod recommendation- blank canvas
hey guys. I am new here and am looking for some advice. I have an '03 6.0. I have put all 120000 miles on it, and with no problems. I am looking into doing some performance upgrades. I would like to add more power, but not so much that I am going to chew through my transmission. I use the truck for towing on long trips about 6-10 times a year. The rest of the time it is my daily driver. Any recommendations?
Old Oct 4, 2009 | 09:49 PM
coyropin's Avatar
get a good tuner that the best way to get power for your buck exhaust and intake,
Old Oct 4, 2009 | 09:51 PM
crewed powerstroke's Avatar
SCT with some custom tunes would probably be a good place to start.
Old Oct 7, 2009 | 06:16 PM
Big Angry Hillbilly's Avatar
Install head studs before you do anything else. One of these engines will toss head gaskets before you hang a tuner on it, so it's just easier to get that out of the way before you start modifying.
Just my opinion.
Old Oct 8, 2009 | 08:14 PM
smokindiesel79's Avatar
Sct custom tunes from innovative, exuast.
Old Oct 25, 2009 | 03:47 AM
Figurhead's Avatar
I got an 03 6.0l w/55k miles on it earlier this year, and the computer had issues "learning" the turbo. Had it checked out at OCdieselshop, and the engine was due for a major tuning. This is what we found, AFTER we took the cab off & took the engine apart.
EGR Cooler was leaking
Headgaskets were begining to leak
Turbo ring was cracked
So I decided to go all out and fix it so I wouldn't be on the side of the road somewhere.
ARP Headstuds
New Stainless EGR Cooler
Banks intercooler/intake elbow
New turbo
All new filters, check HPOP, oil cooler, etc
SCT X3 custom tuned by eric @ innovative
Intercooler had been replaced once (before I owned it).
Already had 4" exhaust w/no cat & an AFE intake filter.
Removed the original Edge programmer
It ran really nice after all the work was done (by Bud), but really moved after the truck was programmed. Big Angry Hillbilly is right, I don't think it's his 'opinion'. It's a fact......... EGR Cooler leaks, Coolant (produces cylinder lock?) & stretches head bolts, then the head gaskets blow. And a tuner will only increase EGT's and thus increase the likelyhood of killing the EGR Cooler. Bad cyclical process Replace the headbolts first, with ARP headstuds, then eric can get more out of your truck with his tunes. The X3 programmer would have killed the truck, if I didn't do everything mentioned above, first.
Since then I have added 12 gauges, since I love to monitor (almost) everything; mostly analog gauges, for direct readings.
Oil Temp & Pressure
Boost / EGT's
H20 Temp
HPOP Pressure
Fuel pressure
Volts/Amps
Trans & Diff Temps
Clock (this is really important)
People laugh and say I drive in an airplane cockpit, but I love it.
Old Oct 26, 2009 | 03:48 PM
Weeks327's Avatar
How many hours on average does it take to lift the cab up?
Old Oct 26, 2009 | 06:16 PM
TU10X's Avatar
Default Lifting Cab
I have that same question and have tried searching for some kind of post or anything that kind of give you an idea as to what it will take, from what I hear some people are removing the air cond box and doing it in the truck but the hardest part seems to be getting the torque done with the cab in the way, maybe somebody will chime in and give some idea
Old Oct 31, 2009 | 10:41 PM
coyropin's Avatar
are work takes are trucks down to ford and it takes any where from 6-8 hours for the 6.0 but i heard the 6.4 is 2-4 hours
Old Nov 2, 2009 | 01:15 AM
Figurhead's Avatar
Bud @ ocdieselshop has been doing it for many years. I think there are 6-10 main bolts, and the cab comes right off. I think it took them a few hours to unbolt it and lift it up. The overall job is much quicker (headstuds), even with the cab removal VS trying to do it with the cab on.
