steering & a/c clutch
Old Oct 4, 2009 | 11:20 AM
country_boy's Avatar
Default steering & a/c clutch
ive got a couple probs with my truck. first off every once in a while when i go to turn a corner my front end will start jerking like im in 4wd. its no though cuz when i step on it just the rear tires spin. second- when i turn just the blower fan on u can hear the a/c clutch kick on and off. whats causing these things?
Old Oct 4, 2009 | 12:02 PM
Hammer's Avatar
Front end doing what your saying is usually a bad inner axle u-joint.
If your using the defroster the A/C compressor will kick on and off as it is supposed to work when you use it.If your talking just using the heat and the A/C compressor is kicking in and out then either you have a bad switch assembly or a vacum leak to the switch.
Turbo67
Jul 25, 2015 02:26 PM
Boostaddiction
May 4, 2015 06:28 AM
BubbaDT55
Apr 12, 2015 10:47 PM
Wyocumins
Oct 19, 2014 09:34 PM
sweetv8s10
Oct 7, 2014 09:47 PM
