cruise control
Old Oct 4, 2009 | 01:13 AM
dan33klein's Avatar
Default cruise control
my cruise worked just fine when i bought my truck. now about 2 weeks ago it all of a sudden stopped work. the light doesnt even come on when i press the on off buttom. any ideas?
Old Oct 4, 2009 | 09:54 AM
96blackcloud's Avatar
mine doesnt work either, check into the clock spring in the steering colum thats what i was told it was, kind of a pain to get to behind the air bag.
Old Oct 4, 2009 | 09:58 AM
colt45_usmc's Avatar
when mine quit it was a short time after that all my electronics went down and i figured out that my crank shaft position sensor was burnt up. might check there for a short b4 trying to go inside the steering column
Old Oct 4, 2009 | 02:40 PM
lodal cummins's Avatar
my green light comes on but cruise not working. pulled my battery box to make sure vacum line was not pinched. checked all vacum lines and they are fine. got power going to cruise unit mounted on botton of battery box. any ideas?????
Old Oct 4, 2009 | 03:12 PM
12vcummins96's Avatar
sounds like your clock spring and also check fuses and relays
Old Oct 4, 2009 | 04:13 PM
thanksi will do a relay and fuse check. sound like the clock springis a pain in the ***!!!! so that will be last on the list. thanks alot!!!!!!
Old Oct 4, 2009 | 04:51 PM
Hammer's Avatar
There is a recall on the clock springs if your truck has not had it done already.
Call the dealers with your vin and they will be able to tell you what outstanding recalls need to be adressed.
Old Oct 4, 2009 | 06:03 PM
really!!? that would save me the pain of doin it not to mention clock springs can be a bit pricy. sounds like i need to give em a call
Old Oct 4, 2009 | 06:31 PM
wow!!!! so if mine has not been done yet they will do it for free no questions asked????
Old Oct 5, 2009 | 12:19 AM
Hammer's Avatar
Clock springs,throttle linkage and trailer hitch were three of the ones which I remember they did on mine way back when.I know there were a couple of more but the previous owner had them done.If its recall then if its not been done they have to do it per federal law.
burndiesel
10
Feb 7, 2023 01:15 AM
JBearSVT
Jul 9, 2015 06:16 PM
jdnetx
Jul 2, 2015 07:38 AM
Oil Igniter
Nov 27, 2014 05:56 PM
Cliffordthe24v
Nov 6, 2014 12:19 PM
