How to find rearend ratio?
Old Oct 3, 2009 | 08:38 PM
AF1CUMMINS's Avatar
Default How to find rearend ratio?
Ok, other than pullin the dif covers, how can I find out what my rearend ratio is?
Old Oct 3, 2009 | 09:32 PM
Sticker inside the glove box
Old Oct 3, 2009 | 09:35 PM
2500HeavyDuty's Avatar
jack ur rear end off the ground, spin the tire around once, count how many times your driveshaft spins and thats ur gear ratio.
make sure to use proper lifting methods when jacking up your truck
Old Oct 3, 2009 | 09:48 PM
01quadcab's Avatar
read tag on rear end
Old Oct 3, 2009 | 10:16 PM
Yes, usually there is a tag on one of the bolts on the rear diff.
Old Oct 3, 2009 | 11:26 PM
PSD's Avatar
PSD
Tag on rear end. Might have to scrape some rust off to see it. Or information in on door. Most likely a code that youd have to look up.
Old Oct 3, 2009 | 11:32 PM
No on a Dodge there is usually a sticker than has the gear ratio on it....On my 98, its under the hood and I think on the 01 - its on the door jam. No code - the ratio should be in plain sight.
Old Oct 4, 2009 | 10:17 PM
It is also on the sticker inside the glove box.
greasesheik
Aug 26, 2015 01:28 PM
Callmecowboy
Jun 27, 2015 04:30 PM
six speed
Jun 26, 2015 09:35 PM
Jan 5, 2015 01:40 AM
Nov 12, 2014 06:10 PM
