A/C pulley
Old Oct 3, 2009 | 12:36 PM
cummins95's Avatar
Default A/C pulley
2 of the tabs for the clutch that engages the a/c compressor broke off, now it grinds against the pulley and its really annoying. im thinkin just hold it out n jb weld it, or should i just get a pulley from a junk yard?
Old Oct 3, 2009 | 04:52 PM
12valvetater's Avatar
i would get a new used pulley ab weld works ok but vibration takes its tole over time
Old Oct 3, 2009 | 06:25 PM
Hammer's Avatar
I would get a belt and route around the A/C using the non-A/C routing.
If your problem is with the A/C compressor clutch then you would be better off to replace the entire unit(compressor/clutch)as a whole rather than just the clutch.
Old Oct 3, 2009 | 06:56 PM
cummins95's Avatar
well the A/C works fine its just when its off n the pulley is free wheelin, it grinds, sounds crappy and its drivin me nuts, i still would like to have the a/c for the summer.
guess i'll just call the junkyard n see if they got a pulley, or maybe i'll check all these damn fords i got layin around....
Old Oct 4, 2009 | 01:28 AM
joshmock's Avatar
just get a new one from the parts store. maybe 35-40 bucks and there ya go. it'll be pressed on there so rent you a puller, it'll make it much easier than banging it off. switch em out and put her back together. then enjoy the sound of no grinding again!
Maclain Marsh
Jul 13, 2015 06:23 PM
Jladanyi
Jul 4, 2015 02:43 PM
CumminsCoalRoller24/7
May 5, 2015 08:55 PM
JasonG.
Ford Powerstroke 08-10 6.4L
Feb 26, 2015 08:51 PM
cumminsblazer
Dec 16, 2014 06:22 PM
