01 ram 3500 heated seat
Old Oct 3, 2009 | 01:10 AM
firstdiesel's Avatar
Default 01 ram 3500 heated seat
Wondering if any body could help me? My driverside heated seat does not work, and the guy i had bought the truck off of(my uncle) said he had it rebuilt twice and did not fix it. When you press the button the light just blinks! Anybody know?
Old Oct 3, 2009 | 01:17 AM
This is from the FSM - and should help -
You could also try swapping the seat heater relay in the Power Distribution Center under the hood, but its looks like the element is either open or shorted.
Check this out - you should be able to check continuity of the element:
Old Oct 4, 2009 | 01:03 AM
i will look tomorrow and let you know
Old Oct 8, 2009 | 04:42 PM
i cannot find the relays under the hood. there is only one fuse box under the hood?
i removed the drivers seat cushin and pluged it in the passenger side, and it worked fine. Tried swaping the switches in the dash still did not work, light still blinks. looked in the fuse box in the driverside dash, and the one under the hood on the driverside. Does anyone have a copy of the wiring manual? That might help. if there is relays i cant find them.
Last edited by firstdiesel; Oct 8, 2009 at 04:42 PM. Reason: Automerged Doublepost
Old Oct 10, 2009 | 10:51 PM
Xforce_nut's Avatar
Default seats
I am having the same issue but the Driver side is blinking on the high and the pass. is blinking on the low. Any info would be helpful...
Old Oct 10, 2009 | 11:09 PM
Look at my post above - tells you exactly what the problem is - from the factory service manual
Old Oct 11, 2009 | 08:42 AM
anybody know where these realys are?
Old Oct 11, 2009 | 12:25 PM
mishkaya's Avatar
According to the FSM, the heated seat relay is in the dash fuse compartment immediately above the flasher , (below fuses one and two I believe). Hope this helps.
Old Oct 11, 2009 | 07:56 PM
Sorry, I should have went out and checked my truck.
Old Oct 12, 2009 | 07:45 AM
i checked in my fuse box on the driverside in the cab, and i found the relay above the flasher but there is only one relay, do both seats go through the same one?
