power steering hissing
Old Oct 2, 2009 | 11:16 PM
smitty's Avatar
Unhappy power steering hissing
Hi I have a 2005 dodge ram. My issue is that I am getting a hissing sound when I turn the steering wheel. The sound goes away as soon as the brakes are applied. Also feels like steering is not as strong as it should be. I hate to start replacing parts until I fix it. Any help is greatly appreciated.
Old Oct 2, 2009 | 11:31 PM
wildbill's Avatar
Try doing a flush first. Also, do an inspection of the steering assembly.
Old Oct 3, 2009 | 01:44 AM
I would recommend synthetic power steering fluid. Makes a difference.
Old Oct 4, 2009 | 08:37 AM
handymanherb's Avatar
Banned
So have we got flush instructions somewhere
Old Oct 4, 2009 | 01:20 PM
tower_ofpower's Avatar
hmmm i'm not too sure about this; but i assume leaving the whole system together other than a return line at the furthest point or closest to the pump w/o the resevoir drainign and turning the wheels should evacuate the system; then do the same thing with a little bit of the new stuff to get all the old out. i'm sure someone will jump in and tell you how to do it correctly as i am just talking out of my ****; but good luck
Old Mar 16, 2010 | 11:21 AM
Eric B's Avatar
you can undo both the coler lines and jack the front up just off the ground and work it left and right then replace the lines and clamps and refill with atf+4 only start it and turn back and forth but stop when it hisses and shut it off and fill again. you will have to do this a few time then pump the brakes 25-30 time after you get all the air out by turninbg the wheel. good luck it worked great on mine
Old Mar 16, 2010 | 11:57 AM
NadirPoint's Avatar
I run a Magnefine filter on the return line to help avoid potential problems with the hydroboost/steering systems. Change fluid every couple-three years and throw on a new filter. Been running various trucks and cars like this for decades, no issues ever.
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
krg3590
Mar 15, 2015 08:57 AM
1MooseheadPlease
Oct 13, 2014 05:33 AM
sweetv8s10
Oct 7, 2014 09:47 PM
