boost gauge
Old Oct 2, 2009 | 04:32 PM
12valvetater's Avatar
Default boost gauge
we are putting gauges in my buddies truck where is a good place to put the boost gauge ive never done this on a duramax
Old Oct 2, 2009 | 05:46 PM
dieseldocter16's Avatar
I'd say on the A-pillar. If your lookin for something cleaner check out the BD X-monitor.
Old Oct 2, 2009 | 06:06 PM
2500HeavyDuty's Avatar
a good place to tap for a boost gauge?
on a lb7 the easiest would be to put a T-tap in the wastegate line
Old Oct 2, 2009 | 11:17 PM
i meant the fitting for the line a t-tap can you explain a little more could i just drill and tap into one of his boost tubes?
Old Oct 3, 2009 | 01:33 PM
its easier to to a t-tap, two 1/4 barbs with a tee cut the wastegate line in half and u set.
Old Oct 3, 2009 | 05:09 PM
10 4 would this fitting come with is gauge i ust looked at the gauge face in the box and didnt go digging around inside my hands were kinda greasy from putting on his new exhaust manifold
Old Oct 3, 2009 | 06:56 PM
the only fitting that owuld come with the gauge would be the compression fittings to attach the nylon hose to your tap. you can stick that onto your tee
Old Oct 4, 2009 | 03:25 AM
well he wants to run a boost fooler so i put it in the intake pipe
Old Oct 4, 2009 | 05:41 AM
hotlb7's Avatar
that wont give you a trure reading dont do it. tap it in the pipe before intake manifold.
Old Oct 5, 2009 | 01:19 AM
that be what i done fella
