86 f250 6.9 starting but does not stay running
my truck i just got from my father in law. will start and run for about 30-60 seconds and die. i have replace the lift pump and put a new injector seal kit on it. so i am wondering if there is something i am missing, any idea?
i know on the fuel system there is a little screw. im pretty sure its right after the injector pump or on it. i did this a long time ago so i dont remember too well. take the screw out and clean it, and then clean the hole its in. i cant remember what exactly it does but i had this exact problem and that cured it. sorry i couldnt give you more.
try to replace your fuel filter mybuddy had the same problem the fuel filter was really dirty. when he was waiting for the wait to start light to turn off the filter was being filled with fuel then when the engine started it would use the fuel in the filter then die out. so i would try replacing the fuel filter
you shoulda replaced the fuel filter first.... as they said, i bet thats your problem...
just for future, any time it feels like its runnin out of fuel, change the fuel filter... its a cheap place to start...
