got an airdog 150 had nothing but problems
Old Oct 1, 2009 | 01:40 AM
cummin along's Avatar
Default got an airdog 150 had nothing but problems
i have a 98.5 24 valve and i put a new vp 44 in it along with an airdog 150 i havnt been able to get a fuel pressure reading yet but the truck will continously hiccup and almost missfire at an idle. i was driving on the interstate running about 70 mph when the truck just fell on its face and i got a dead pedal. it picked back up and i drove it to my house immediatly where it died and would not start even with a cracked injector line or two.i have been having a rough idle for about a week now and i continously drain the filter on the airdog. the pickup tube is about 2 inches off the bottom of the tank. now when i bump the key to get the pump to prime it clicks twice and stops. can anyone help me.
Old Oct 1, 2009 | 01:51 AM
stkdram55's Avatar
well the pickup tube being 2 inches off the bottom is gonna be a huge problem, not with a full tank but when it gets low...mine is 2 quarters off the bottom of my tank and i mean i put 2 US quarters on the bottom of the tank and then thats how long i cut the pipe to...
will the pump run at all...if almost sounds like the pump isnt running right and maybe something is stuck in it
Old Oct 1, 2009 | 06:01 AM
Jazz's Avatar
I would have to say the pump also. If it clicks, you have power to it but why it doesn't run I'm not sure on that. The airdog has been in a week? And the day of install you had the rough idle right away?
Old Oct 1, 2009 | 06:08 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
give airdog a call
Old Oct 1, 2009 | 08:30 PM
i cut the pickup tube last night and the truck is runnin alot better but it still has the hiccup at an idle.there are some occasions where it will run perfect and idle with no problems whatsoever. i almost think it could be a bad injector or two but then again everyone i talk to says the injectors either work or they dont. i also have the expandit 5 inch exhaust i got from luke at diesel dawgs and when i get on it the truck crackles kinda like a 6.0 powerstroke and it wont blacksmoke at all. should i just buy some better injectors and see if it cures the problem or try to clean the stock ones that are in it?
Old Oct 1, 2009 | 08:38 PM
Jet A Fuel's Avatar
Have you got a Fuel Pressure gauge on your truck?
Old Oct 1, 2009 | 09:01 PM
MotorOilMcCall's Avatar
FP reading, and if it doesn't get better with proper FP, then have the injectors pop tested.
Old Oct 1, 2009 | 09:36 PM
tower_ofpower's Avatar
i'm not too familar with the operation of the VP44 but everyone sems to overlook that he put a new IP in and there's a popping noise under load... have you double checked your timing? low fuel pressure can cause the same symptoms; so everyone else is right on too; just dont ignore the other half of the equation that's all i'm saying
Old Oct 1, 2009 | 09:37 PM
FP guage x 3
Old Oct 1, 2009 | 09:38 PM
also sounds like the pump isnt too healthy; it'd be the first problem i've heard of these pumps having
