What is needed
Old Sep 30, 2009 | 09:45 PM
baxterboy's Avatar
Default What is needed
Hello gents, wondering what is needed to build a stock 09 Dodge short box c/cab 4 X 4 to approx 600 RWHP. I currently have (2) 2005 Chevs with 500 RWHP so I was wondering if most things are the same on a dodge build? Tranny, lift pumps, ECT? Currently run EFI live on them. Do you stack programmers. Thanks in advance. Also truck is going to be lifted with 35s on it.
Old Oct 1, 2009 | 12:30 PM
tower_ofpower's Avatar
fundamentals of diesels are even across the grid; more air more fuel= more power... better tranmission= better transfer of that power... look into an upgraded charger (i cant help you there) stack is possible... there are some killer stacks that guys run on here; look around in the forums... smarty seems to be a very popular tuner to start with (i also believe this is one of the only prgrammers that block DTC's from the emissions crap). up the injectors and up the fuel supply to flow the injectors, add a turbo and a programmer to open up the parameters; unchoke the intake and exhaust and i think you'll be set other than the trans upgrades. before i get slapped GAUGES! they arent just decoration or an ego booster to make you think the truck is hotter than it is... they are a MUST
i still may get slapped... i started to run off at the mouth before i actually thought it out... some of the stuff is very limited for the 6.7's not a whole lot of companies are fooling with programmers for these trucks IIRC
Last edited by tower_ofpower; Oct 1, 2009 at 12:30 PM. Reason: Automerged Doublepost
Old Oct 1, 2009 | 05:03 PM
cumminscontrol's Avatar
on the 09 dodges im hearin alot about any programmers that are installed are puttin the trucks in limp mode and killin the ECM even on the earlier 6.7's dealers are reflashin the ECM when u take the truck in, for any repair, without tellin u, so that a programmer will not communicate. i kno i aint takin my truck back 2 the stealership
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
Strictly Diesel
Strictly Diesel
Jun 30, 2015 06:48 PM
Crwln73
Jun 24, 2015 05:14 PM
klein444
Jun 20, 2015 11:48 PM
SixSpeed
Jan 11, 2015 01:41 AM
