manifolds cooldown cracking noise after shutting down
Old Sep 30, 2009 | 05:03 PM
bm8022's Avatar
Default manifolds cooldown cracking noise after shutting down
I replaced all my injectors in 6.6 duramax. after install my manifolds sound like they are running real hot. when I shut the truck off they make a cracking noise for about ten min.
Old Sep 30, 2009 | 05:21 PM
Please post in the correct forum
Old Sep 30, 2009 | 06:06 PM
mysterync's Avatar
Could be caused by fluids you may have spilled on the manifold, Could be corrosion on the the bolts and such breaking loose, could just be normal Might check the bolts and gaskets, The manifolds in what i consider a high corrosion area!
Just my opinion
Old Sep 30, 2009 | 07:24 PM
2500HeavyDuty's Avatar
could be even them contracting as they cool off
jcfarms2000
Jun 16, 2015 10:22 PM
Boatman
Mar 20, 2015 10:00 AM
2FordStrokers
Jan 11, 2015 09:40 PM
