High idle?
Old Sep 30, 2009 | 02:30 PM
Pyro690's Avatar
Default High idle?
I'm guessing that using cruise for high idle, it doesn't on any other truck. I don't like having to use a stick but a cable might work(I want it to be user friendly for the ol lady). Is there a way to fool the cruise to think the truck is moving to use it as a high idle, or is this just a pipe dream? And yes I like to think outside the box. Haha.
Old Sep 30, 2009 | 10:07 PM
tower_ofpower's Avatar
hmmm i dont believe so... it goes by vehicle speed; you could wire up a toggle switch that engages the cruise but you'd then have to rig a stop on it so that it'd only travel so far as i assume if you engage the cruise manually it'll just peg the rpm's... how ever i have been thinking about doing it on my first gen; if you get on summit they have idle compensators for old carbureted engines so when the A/C kicked on it'd open the throttle up a little bit... idk if the thing itself is adjustable or if you have to adjust the mount; but i'd try doing this before messing with the cruise. buy it mount it and adjust it; wire it up to a toggle simple on/off operation and it wouldnt interfere with normal cruise operation
Old Sep 30, 2009 | 11:00 PM
12valvetater's Avatar
my high is idel is a pipe in the bed off my truck i use for binders you just jam it between the throttle and seat adjust the seat to set the speed
Old Oct 1, 2009 | 11:16 AM
gotta love it
Old Oct 1, 2009 | 12:35 PM
Pyro690's Avatar
Thanks tower.
Old Oct 1, 2009 | 12:59 PM
no problem bud, looked them up too... just search for "idle compensator" or "throttle actuator" i'm guessing since it has a hex head design the shank itself is adjustable... obviously the bracket isnt made for the cummins so modification will be needed; 75 bucks for the holley brand which doesnt come with the bracket or even lock nut and 109 for the edelbrock one with all the hardware... if you bend the living **** out of the bracket you might be able to make it work
john grossman
10
Jan 12, 2019 08:58 PM
robbyS
Apr 16, 2015 02:22 PM
CumminsCoalRoller24/7
Feb 21, 2015 10:44 PM
robbyS
13
Dec 20, 2014 04:25 PM
jmerriman17
Nov 21, 2014 04:38 PM
