Engine driven air compressors
Old Sep 30, 2009 | 05:41 AM
MarineOne's Avatar
Default Engine driven air compressors
I want to add an EDC to my '08 6.7 for air accessories like my airbags, airing up tires on my truck/RV/four wheelers/etc., a pneumatic wrench (similar to an impact wrench) for my RV to raise/lower the stabilizers when I park it, air horns (I got cut off when pulling my 26 foot Keystone RV/toyhauler), and be able to help someone else if they need it.
I've looked at some of the electric kits and I don't want to mount it in the bed of my truck since the air tank will probably be mounted on the passenger side frame rail. I want it totally out of visual view and out of the elements as well, but need to be able to service it, too.
OTOH, I've seen some really high end EDC's that start off around $10,000 .... and obviously thats overkill.
I can't find anything in between.
Other than Kilby Enterprises (they have a 5.9 kit, but no 6.7 kit) is there anyone else that makes something like this for the 6.7L engine?
Thanks.
Kris
Old Sep 30, 2009 | 07:07 AM
2low4nh's Avatar
look into york air compressors they are EDC. i personallyuse viair compessors on my mini truck i have them mounted under my bed. they are not very fast but run up to 200 psi. theywok best on a 5 gallon tank. they will run air tools but you will have to wait around alot. EDC's are much faster but more expensive.
by the way i like how you spell your name!!!!! no many kris with a k's out there
Old Oct 1, 2009 | 04:34 AM
millco's Avatar
Also, I would check with a prospective supplier if it would fit anyway. There is a lot of similarities between the 5.9L and the 6.7L Some of them may work anyway and just not list it yet....
Old Oct 1, 2009 | 05:21 AM
gwhammy's Avatar
I've had a kilby oba on a number of trucks for around 8 years. Other than burning up a couple of compressors and a belt change every now and then they work flawless. Probably the best setup for the money.
Old Oct 12, 2009 | 02:30 AM
MarineOne's Avatar
I'd go with Kilby but they don't have a kit for the '08 yet. I'd let them borrow it if I were close to SoCal so they could build up a kit. Unfortunately, I'm not
Kris
burndiesel
10
Feb 7, 2023 01:15 AM
carid
Diesel Bombers Sponsors
May 27, 2015 07:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
