Bully Dog Triple Dog
Old Jul 10, 2007 | 10:10 PM
062500d's Avatar
Default Bully Dog Triple Dog
hey guys i just got the bully dog and installed on my truck with the crazy larry setting...i just wanted to know what settings you guys r running and what setting your using for transmisson(aggressive,smooth,stock)? and if i should have to worry about anything while in crazy larry mode????
Thanks for your help....
Old Jul 10, 2007 | 10:16 PM
Diesel Nut's Avatar
The Crazy larry setting is an agressive setting. It will inject more fuel than your stock turbo will let you burn and will tear up a transmission in short order if thrashed on. You really need gauges since you didn't mention getting the outlook monitor. EGTs are very important as they will cause damage to the motor if kept unchecked.
The Crazy Larry program will yield some great mileage, just be careful about romping on it too hard too often.
Old Jul 10, 2007 | 10:19 PM
062500d's Avatar
well at the most i push the pedel in half way....not sure if thats too much or not....
Old Jul 11, 2007 | 09:41 AM
CHenry's Avatar
Vegistrokin Bombardier
GET GUAGES...QUICK!
I can push 1140* egts in stock mode pulling my 5er up a grade, at WOT. Add a tuner that is dumping more fuel in and you can hit 1500 easy if you aren't carefull and you won't know this untill you get a egt guage or untill you toast your turbo.
Old Jul 11, 2007 | 10:26 AM
powerstroke07's Avatar
Listen to Clay, I can hit 1300 quickly if I am not paying attention. A quadzilla commander could definitely do you some good. I have one and so does he and they work great.
Old Jul 11, 2007 | 10:39 AM
CHenry's Avatar
Yes, i preffer the exactness of the digital readout that the Commander gives you rather than a mechanical guage with a needle and numbers
Old Jul 11, 2007 | 12:43 PM
062500d's Avatar
ok i'll get one as soon as possible.....i have another question....when i give 50% throttle and get the rpms around 3000 then release the throttle it kinda jerks and makes a thump sound.....i think the jerk is normal but the sound?????
Old Jul 16, 2007 | 08:41 AM
megadually's Avatar
Are you running more boost? I had a triple dog w/outlook in my last 06 and it made a big difference once they came out with a boost fooler for it. I gained some power on top by burning all my fuel and it realy lowered my egts.
Old Aug 3, 2007 | 06:12 PM
spike7ss's Avatar
I got my Bully dog now, are you sure there is an adjustment for tranny settings?
Old Aug 28, 2007 | 12:30 AM
Townsend600's Avatar
I just recently downloaded V2.4.1 w/ crazy larry on my cummins and it allows for tire size, rev limiter, and speedo as new options but I haven't seen ne thing on tranny adj. out of bully dog yet.
