Blue Smoke
Old Sep 28, 2009 | 11:02 AM
churkeepwrstrke's Avatar
Default Blue Smoke
i noticed the other day that my 05 f-350 was puffing a bluish gray smoke whenever i take off. its not a lot but noticiable. its seems to lightn up when the truck get warmed up any ideas????
Old Sep 28, 2009 | 12:05 PM
Big Angry Hillbilly's Avatar
Usually blue smoke is oil related. Check all fluid levels and report back.
Does the truck run OK when cold?
Old Sep 28, 2009 | 02:09 PM
i checked them the other day oil was a little low. put some in still the same. it runs the same as it always has. cant tell any difference other than the smoke.
Old Sep 28, 2009 | 02:49 PM
Check engine lamp on, by chance? Truck run okay otherwise?
Air filter OK? If there's inlet restriction it will pull the seals out of the turbo.
Old Sep 29, 2009 | 06:48 AM
should be fine got an afe stage 2. i cleaned it a few thousand miles ago.
and no. no engine light, it runs fine.
Last edited by churkeepwrstrke; Sep 29, 2009 at 06:48 AM. Reason: Automerged Doublepost
Old Sep 30, 2009 | 06:51 PM
TYPICALLY trucks that smoke when cold but don't once it warms up have some ratty injectors in them - however, they will also run like a total can of garbage while cold.
Truck still got warranty?
Old Oct 1, 2009 | 05:32 PM
no. it doesnt seem to run any different. warranty was up about 2 months ago. i did have an injector replaced like 2 times tho. could egr possibly be goin again? it been replaced 3 times. id like to get a delete kit when funds are avalible. i checked for codes but none found.
Old Oct 1, 2009 | 07:06 PM
04redstroker's Avatar
An injector could have a small leak that bleeds out when the truck isnt running. Also, it could maybe be bad turbo seals. Hard to say without seein it.
Old Oct 3, 2009 | 07:46 PM
yea. keep an eye on it i guess
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
tim12valve
Jun 16, 2015 09:59 AM
gagemotors
Jun 9, 2015 04:24 AM
honda89
Dec 27, 2014 06:19 PM
lil red
Oct 10, 2014 09:03 AM
