Mighty Diesel Visit - Mighty Diesel
Smarty S-67
Old Sep 30, 2009 | 06:51 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
Default Smarty S-67
AVAILABLE FROM MIGHTY DIESEL 877-354-7008
Smarty S-67 for Dodge Cummins Turbodiesel 6.7L (2007 - )
Smarty’s Special Features:
*CaTCHER software's inside
*Ten different performance levels
*Fastest download in the industry, up to three times faster than
the competition, a typical ECM update takes about 5 minutes
*ABS tire height updates in just few seconds
*Manual High Idle is enabled in all softwares
*Reads Diagnostic Trouble Codes in plain text
*No tools required, no fuses to pull
*USB built in for simple updates
*Free internet updates
*Most complete keyboard in the industry
*Reliable, it works off your OEM hardware
*Programmable Speed Limiter from 25 to 250 mph
*Programmable parameters for fine tuning
*"On the fly" Power on Demand under development
*TNT softwares under advanced development
Smarty's software levels:
*The horsepower settings. except #0, all other softwares have a
modified "Torque management" ( TQM ). The throttle response
is greatly improved but is set to a save limit. With "Save" I mean
save for your tranny and rest of the driveline.
SW # 0 : Half power
SW # 1 : 30 Hp increase, with added timing
SW # 2 : 60 Hp increase, no added timing ***
SW # 3 : 60 Hp increase, with added timing
SW # 4 : 90 Hp increase, no added timing ***
SW # 5 : 90 Hp increase, with added timing
SW # 6 : 130 Hp increase, no added timing ***
SW # 7 : 130 Hp increase, with added timing
SW # 8 : 170 Hp increase, no added timing *** °°°
SW # 9 : 170 Hp increase, with added timing °°°
°°° Do not use for prolonged high speed runs! Speeds exceeding approx
105 mph can result in high exhaust gas temperatures and damage the
Diesel Particulate Filter (DPF) !!!
*** All even numbered softwares (2-4-6-8) without timing are to be used
for stacking with other after market power adding devices that also add
their own timing. NO additional timing has to be used with the odd
numbered softwares (1-3-5-7-9).
Severe engine damage will result !!!
**ATTENTION** Smarty S67 has not been tested on 2009 trucks
with ECM bootloader software produced after the date 03-04-
2009 according to the service bulletin 18-007-09.
Please check the production date present on the ECM before
install the CaTCHER software.
TO ORDER CALL 877-354-7008
bump
bump
bump
bump
Last edited by diesel pap; Sep 30, 2009 at 06:51 AM. Reason: Automerged Doublepost
Old Oct 3, 2009 | 08:22 AM
diesel pap's Avatar
bump
Old Oct 12, 2009 | 03:52 PM
diesel pap's Avatar
this can be used with 07.5 and 08s that where flashed and locked out
05cumminsCA
8
Feb 3, 2015 09:29 PM
jdepuy618
For Sale
Dec 21, 2014 05:28 PM
5.9sledhead
Price Quote - Request A Price
Oct 28, 2014 11:43 PM
