Falling on its face at WOT
Old Sep 27, 2009 | 02:57 AM
TXAustin's Avatar
Default Falling on its face at WOT
I know it has to be a fuel issue now, but on level 6 at WOT about 5 seconds into it the truck just boggs down. Turned off all safety on the edge and the problem still happens. The load % hits 100 and it is almost as like the truck defuels itself. Time for an airdog, CP3, or what?
Thanks, Austin
Old Sep 27, 2009 | 03:30 AM
DB Admin's Avatar
Banned
Sounds like your running out of fuel. Air Dog FTW
Old Sep 27, 2009 | 07:54 AM
wildbill's Avatar
Yep, then have the fuel pressure on the high side tested. Chances are you damaged the CP3.
Old Sep 27, 2009 | 12:27 PM
TXAustin's Avatar
Thats just great, but it is what I expected. Is there a modded cp3 I should look at? The cp3 I am still gathering information about.
The lift pump was replaced about 30k miles ago so I would hate to have to buy an airdog already. Plus I am thinking that the cp3 was replaced after I bought the truck(old owner never replaced the fuel filter often and had to replace quite a few parts, $2000 worth)
Old Sep 27, 2009 | 02:13 PM
2500HeavyDuty's Avatar
before you go spending all kinds of money on luft pumps or cp3's you should test to see if that is your problem. it could be the fprv popping or maybe it is the cp3. using a gauge to measure the rail pressure and fuel supply pressure to the cp3 will help you make the right desicsion for the next upgrade
Old Sep 27, 2009 | 03:11 PM
TXAustin's Avatar
Unfortunatly, I am at college and my well trusted mechanic is a couple hundred miles away. Hopefully sometime this week I will be able to go to NAPA and ask who the trusted diesel mechanic is for the area. I'm putting my bet on a CP3, but we will find out soon enough!
Thanks, Austin
Old Sep 28, 2009 | 04:50 PM
TXAustin's Avatar
Was able to go to the shop today, everything on the fuel checked out fine! went into the Edge and found out that the alert EGT is different from the Max EGT and I havent been able to test it a whole lot but that seemed to fix my problem! The truck was actually defueling itself because of my unknowing "two" alert systems the edge has.
NEW PROBLEM
On my way back I stopped and got something to eat. After I came back out I started it up and it sounds like you can hear a "turbo wobble" through the stacks. It is a loss of power and shakes the truck when you come to a stop. At idle in drive the load % is 28, when it is normally at 15%. When I take off from a light there is more smoke than normal coming out of the stacks at normal throttle percent. It is the oddest sound and this is not the first time it has happened. sounds like the turbo, but the boost PSI is normal. Could be the valves? I'm not sure why it just started happening again!
Let me know what you think!
-Austin
Old Sep 28, 2009 | 05:29 PM
wildbill's Avatar
Remove the Edge completely and see what happens.
Old Sep 28, 2009 | 08:48 PM
TXAustin's Avatar
I drove it around for a little while longer and a code finally popped up
Crankshaft position sensor. Got the code cleared and now it seems to running better, but not great. Im going to call cummins tomorrow and hopefully that part isnt too much!
Jul 13, 2015 08:10 AM
Jan 8, 2015 03:00 AM
Nov 27, 2014 08:00 AM
tbreddiesel
Thoroughbred Diesel
Oct 14, 2014 07:44 AM
