BHAF and Old Smokey mount in the works
Old Sep 27, 2009 | 12:25 AM
tower_ofpower's Avatar
Default BHAF and Old Smokey mount in the works
so, i got abit dangerous with the tape measure a day or two ago, made all of my measurements drew it out on a piece of paper then transfered it all to scale on the big sheet of diamond plate, cut it all out, de-burred it and bent it all up tonight, finish product looks pretty freakin good i think i improved the mount abit so i'm going to include a thing of the blue prints, still not perfect; some added fabrication will be needed... hole for the filter needs to be cut and then the supports for the filter itself aren't included but; here's the semi finished result
Attached Thumbnails BHAF and Old Smokey mount in the works-old-smokey-blueprints.jpg   BHAF and Old Smokey mount in the works-old-smokey.jpg
Old Sep 28, 2009 | 09:47 PM
alright scratch my blue prints... they suck; had to modify and make afew more cuts. but i guess it's easier to take material off than put it back on
Old Oct 2, 2009 | 12:17 AM
big bad diesel 416's Avatar
Site Sponsor
on mine i bolted it to the fender and used those pop rivit things thar are threaded inserts just a thought
Old Oct 2, 2009 | 07:56 PM
i used self tappers to mount it to the fender i have to get a different/ better clamp the factory one snugs it but it isnt overly tight b4 it bottoms out... i've read this is a common problem
