afc trouble
Old Sep 25, 2009 | 11:44 AM
12.valve.hauler's Avatar
Default afc trouble
my buddy has a 97 12v and we were looking for an oil leak when i found that his afc has only one bolt in it. i think two are broke off in it and the other is just gone. does it have to have all four and what the easiest way to get the bolts out? im hoping i dont have to drill and try an easy out em.
Old Sep 25, 2009 | 12:09 PM
DIESELDENT's Avatar
A easy out is probably your best bet and yes it should have all four in there to make sure it doesnt move around on you. Also the shut down sulenoid uses one of the bolts.
Old Sep 25, 2009 | 02:45 PM
94 12valve's Avatar
if you take the housing off do the broken bolts stick up or are they flush with the pump? and the shut down bracket uses 2 bolts.
Old Sep 25, 2009 | 02:51 PM
havent been able to actually get into it yet. i ran into him at a gas station and just took a quick glance at it
Old Sep 25, 2009 | 03:07 PM
94 12valve's Avatar
oh ... well if there sticking up just take the housing off and use a pair of vice grips. as long as there are bolts to hold the houseing on it will be fine. if it moves it goes FF no big deal as long as it doesnt move up and down.
my97-6gun
May 3, 2015 09:43 PM
Gizmo52
Jan 6, 2015 11:58 AM
NiNjAassasin545
Dec 2, 2014 11:40 PM
xj_crawler
12
Nov 20, 2014 10:17 PM
SMatyac
Nov 4, 2014 10:29 PM
