Air Dog Visit - AIR DOG
Air dog for VE pump
Old Sep 24, 2009 | 01:09 AM
D Gandy's Avatar
Default Air dog for VE pump
I plan on purchasing an airdog for a VE engine, but plans down the road are likely to be P-pumped. Will the airdog for the VE pump feed a P-Pump also? Or do I need to by one for a P-pump and use a regulator for the VE pump? Thanks.
Old Sep 24, 2009 | 04:47 AM
DB Admin's Avatar
Banned
a project we are working on Issuu - You Publish , it has manuals for the VE truck install if i recall correctly it was an air dog 100
Old Sep 24, 2009 | 09:33 AM
PureFlowTech's Avatar
The same AirDog pump will work. You will just have to switch out the regulator spring, to be able to boost the pressure enough for the P pump. The installation will also require a 14 mm fitting instead of the 12mm. Other than these two items, the pump will work the same way on both injection pumps. You can purchase both of the items that you will need for less than ten dollars.
Feel free to conatct me if you have any further questions.
Ron
573-635-0555
Old Sep 24, 2009 | 05:55 PM
D Gandy's Avatar
Thanks.
moneypitk5
Feb 12, 2015 11:01 AM
dawnrogerl
Price Quote - Request A Price
Jan 29, 2015 01:03 AM
airspeed181
Jan 19, 2015 09:00 PM
Anh Chà n
Jan 9, 2015 12:45 PM
veggyoilkid
Nov 10, 2014 12:39 PM
