stuck throttle
Old Sep 23, 2009 | 08:01 PM
2low4nh's Avatar
Default stuck throttle
okay ijut bought a 95 dodge with the cummins in it. the throtle is sticking bu i dont think its the cable. im pretty sure its the spring loaded evolving part. anyonehave this issue? looking fo an easy fix
Old Sep 23, 2009 | 09:14 PM
12valvetater's Avatar
there is a linkage there that if it gets twisted will make it stick make sure that he knuckles are inline with each other
Old Sep 23, 2009 | 09:18 PM
Benjamin's Avatar
Bombardier
Call your Dodge dealer and have them run the VIN for any safety recalls. there was a safety recall on the throttle cable and linkage. it is a FREE fix as the cable will fray and will either break or will cause the throttle to stick.
i had this done twice on my 96, both times the cable snapped while driving down the road.... it sux trying to drive while it is idling....
Old Sep 24, 2009 | 08:23 AM
2low4nh's Avatar
will do that thankss for the help
Old Sep 24, 2009 | 12:43 PM
907akjon's Avatar
There is a recall from the dealer on that. You can also get some liquid grafite spray, hold the thottle open and soak it and then work it some. To get you by
Old Sep 24, 2009 | 01:38 PM
Heres the recall - Recall #970 - throttle cable
Did you get yours fixed yet?
Old Sep 24, 2009 | 05:45 PM
dan33klein's Avatar
yes, call the dealer. theres a recall. i had the same problem and it was fixed 2 days later free of charge
12vWoodHauler
Sep 30, 2015 07:58 PM
Blair@BD
BD-Power
Sep 10, 2015 12:29 PM
Jake202
Jun 21, 2015 09:42 PM
Bottlerocket12v
Mar 12, 2015 09:10 PM
1stgenswap
Nov 3, 2014 09:45 PM
