HELP ME!!!
Old Sep 23, 2009 | 03:59 PM
rollincoal12valve's Avatar
Default HELP ME!!!
i dont have any 4th gear lock up my truck will only do 70 mph to the floor!!!
:a rgh:
help please!!!
Old Sep 23, 2009 | 04:32 PM
cummins95's Avatar
will it lock in 3rd? does it kick in and out? if it wont lock in 3rd, check ur O/D off switch. if its not hooked up then u wont have lockup, or if its bad. are ur brake lights stayin on? if so check ur brake switch, when u press the brakes it unlocks the tc so if thats bad it wont lock. if its kickin in n out check ur TPS. thats about as far as my knowledge goes, these other guys know a hell of a lot more than i do.
Old Sep 23, 2009 | 10:06 PM
well here is how it is when overdrive is on it usually locks at 45 mph and when overdrive is off it locks at 30mph now when on it does not lock at all and it will only do 70 when you put it to the floor. the brake switch is good cuz i just replaced it because it was stuck
any ideas?
please tell me i dont need a convertor
if this helps it did kick in and out about a week ago and then it just quit i forgot to mention that my bad
Last edited by rollincoal12valve; Sep 23, 2009 at 10:06 PM. Reason: Automerged Doublepost
Old Sep 23, 2009 | 10:26 PM
xzaq103's Avatar
FormerVendor
also check this out about midway down the page about tps adjustment and claening.
Dodge diesel maintenance tips
Old Sep 24, 2009 | 05:33 PM
thanks im gonna try cleaning my terminals tommorow then ill move on to the tps
cleaned the terminals today no luck
Last edited by rollincoal12valve; Sep 24, 2009 at 05:33 PM. Reason: Automerged Doublepost
Old Sep 24, 2009 | 05:36 PM
Do you have any computer codes?
Old Sep 25, 2009 | 10:25 PM
how do i check those?
both my abs and brake light are on but the truck stops fine and the e brake is off
just looked up and went to check the codes i only have code 12 and 55
could it still be the tps?
or do i need a convertor?
it still locks up when overdrive is off i dont get it
Last edited by rollincoal12valve; Sep 25, 2009 at 10:25 PM. Reason: Automerged Doublepost
