towing twins or a good single towing turbo
Old Sep 22, 2009 | 08:04 PM
oilfldtrash05's Avatar
Default towing twins or a good single towing turbo
I'm trying to find out what kind of luck and experience anyone has had with a towing twin set up, which ones spooled to quick or too slow and my main concern is egt's. which ones helped and which ones didnt thanks
Old Sep 23, 2009 | 12:43 AM
Faster Than Light Diesel's Avatar
towing turbos can someties be hard to spool if there is not fuel at the low end! i have an aurora plus kit on my dodge and it works amazing. mlet me know if i can help!
Old Sep 24, 2009 | 07:29 PM
i got a smarty tnt and a predator pressure box stacked. but i'm not lookin to be fast im just going for mpg and egt's. it's a welding truck so it pretty heavy. how much did you pay for your setup
Old Sep 24, 2009 | 10:18 PM
Check out a set of BD, ATS or Industrial Injection Twins or Fab your own.
Old Sep 24, 2009 | 10:32 PM
12vcummins96's Avatar
i run an aroura 5000 single very happy with it
Old Sep 25, 2009 | 10:11 PM
wildcat's Avatar
Without "other mods" a larger single or twins will present more lag.
If you haven't dropped coin on a Cold Air Intake, (CAI) then go with twins. a little more money, but it's money spent in the right direction for you.
There seems to be a movement toward the Garrett Turbos for twin applications to reduce lag.
I went with a larger single because it was attainable with my financial situation.
Good luck!
Old Sep 25, 2009 | 11:09 PM
midnite><og's Avatar
twins are nice.... they have less work for eachother to do.... but, they also take timeto spool... a single takes less time to spool, but works harder...
Old Sep 26, 2009 | 12:13 AM
tower_ofpower's Avatar
the ATS towing twin set-up uses this 2000 and 3000 series turbo's i believe... quick spool with 45ish psi in the higher psi ranges... visit their site and check it all out, they explain everything pretty clearly, plus from everything i've seen... they're purple... or you could just get one ATS turbo and then nick name your truck the one eyed (turbo), one horned (intake), flying (b/c its so damn fast now) purple people eater... just a thought, and its been a long day
Old Sep 26, 2009 | 12:32 PM
harry22's Avatar
haha oh thats funny, but yet very fitting
Old Sep 26, 2009 | 03:58 PM
i thought so... plus i like the idea of popping the hood with two purple chargers staring at you
CCC1971
6.7L Performance
Nov 20, 2017 04:49 PM
Piedmont Mobile Mechanics
6.4L Performance
Jul 17, 2015 06:35 PM
Ian Roberts
Mar 23, 2015 12:36 AM
Alfred Bruce Millett
Dec 19, 2014 05:17 PM
GreenDieselF
Oct 20, 2014 02:05 PM
