Dipricol Gauge
Old Sep 22, 2009 | 05:47 PM
Fiveseven's Avatar
Default Dipricol Gauge
Hey guys I do you have any idea why is my Fuel Pressure Gauge is flicking and clicking ?
Its reading right have checked it with another one already.
Old Sep 22, 2009 | 05:48 PM
2500HeavyDuty's Avatar
is it mechaanical or electric?
Old Sep 22, 2009 | 06:02 PM
Fiveseven's Avatar
Mechanical
Old Sep 22, 2009 | 09:07 PM
You need a needle valve or a pressure snubber....I would disconnect the guage until you get one. The pulses from the injector pump are hard on the guage and can damage it in no time.
Old Sep 22, 2009 | 11:21 PM
Fiveseven's Avatar
I have put a needle valve I did only opened up a very little just a crack.
Old Sep 22, 2009 | 11:23 PM
I would close it...break the line at the fitting, put the line back together. start the truck and slowly open the needle valve until you just get a smooth reading (maybe 1/16 to 1/8 th of a turn).
Old Sep 22, 2009 | 11:41 PM
Fiveseven's Avatar
Ok I would do that first thing in the mourning . Do you think that would stop the clicking noise? . I was using a aluminum adaption to the needle valve that I found at a hose shop it's a reduction from 1/4 to 1/8 and it has some type of little plastic that you pull down and insert the 1/8 guague line and it locks it in do you think I should go back to the compression fitings that came with.Thanks!
Old Sep 23, 2009 | 08:28 AM
No - I dont think thats what the problem is.
When the guage is making noise, is the needle jumping all over the place? If so, you need to close the needle valve more.
Could be a bad guage but I highly doubt that.
Old Sep 23, 2009 | 12:56 PM
Fiveseven's Avatar
Yes it sounds and looks to me that when the needle is flickering it makes the noise because as soon as I start to step on it the needle does not move from 13 psi and noise stops.
Hey Dr. Evil thanks for the help I did closed it and opened it up just a hair and it's know steady and no noise thanks
Old Sep 23, 2009 | 01:16 PM
Good to hear it
Steve123
Sep 28, 2015 02:36 PM
MrCat4974
Mar 23, 2015 11:30 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
450r racer
Nov 14, 2014 05:11 PM
scottxmorris
Oct 8, 2014 02:14 PM
