Bench seat in rear of Ext cab? Anyone try it?
Hey all L0L its me again. Man I got alot of Questions it seems like about 1st gens!
Anyways Has anyone tryd to put a bench seat in the ext. cab 1st gen dodges? I was looking and wonderin if the bench seat from a dakota would work to where there was still alittle leg room but the main reason I want it is to be able to put a car seat back there and it be in the middle.
Anyways heres a photo of the seats I was thinkin of putting in if yall think itd work. This is the main thing holding me up from deciding on buying a single cab or ext cab 1st gen. If this would work id like the ext. but if it wont i think id rather just get the single cab.
i'm not too familiar with the extended cabs floor design... if it is flat; it may work... the dakota bench seats base is flat and where they "build them up" is used as a storage area... eitherway it will require fabrication of a base, and mounts for everything, other thn that i'm pretty sure it'll all fit... a dakota should be narrower than a first gen so bench seat length shouldnt be a problem
Yeah I think it would work. And I know i'd have to make brackets for the seats and do some support in the cab to make them safe to seat in. But I figured they would fit nicely in the back and there be some room for ppl to sit or just have the car seat in the middle there at least.
But I figured it would be a cheap enough project. The seats are $75.00 so it wont cost me alot if I do decide to get the ext cab. I was just hoping that maybe some one on here had did this or maybe seen something along these lines.
Anyways if anyone else has any ideas let me know. Thanks yall
TC
TC
I think it would be awesome
I have considered this, but after installing a second gen 40/20/40 bench in the front it just feels like there would be 0 legroom in the rear... it's seems like the space is there, but it's not kinda like an optical illusion.
i dont know if you have looked into options but i have seen an 88-98 chevy silverado rear ext cab seat put in a dodge and it looked nice. best part is it only takes a small piece of square tubing on each side to mount it. very simple install
Nick, if you go on 'another' forum and do a search for bench seat or whatever, you'll find a few threads on it. It'd be hard, but not impossible. There's not much leg room back there but folks have done it. Still, if you only want it for a car seat, (I'd really like to put one in my truck, too!) then you don't have to worry about leg room. Maybe look in to tltruckparts suggestion about the Chevy seat.
