injector line leak
Old Sep 21, 2009 | 06:24 PM
nick b's Avatar
Default injector line leak
i have a leak on my 5 and 6 injectors i cannot seem to get it to seal up i have tightened the nut up a few times i am afraid to go any tighter anyone have any ideas on this one
Old Sep 21, 2009 | 07:22 PM
mysterync's Avatar
Most likely the connector tube O-ring. Dont just buy a cheap off the shelf o-ring , Call cummins or dodge and order the correct part number. If thats not it, It's probably over tightning thats caused the leak, Loosen the lines, clean all mating surfaces with emory cloth and re tighten, Fairly snug but not as tight as you can get them by any means..more like 28 ftlbs. on the injector side and 18 ftlbs. on the pump side If neither of these solutions fix it, You'll need new lines for 5 and 6. They'll be available from any vendor here including myself and at your local cummins or dodge store!
Old Sep 21, 2009 | 08:00 PM
vectorboy_99's Avatar
I just had one work it's way loose all it's own. What a nightmare, especially for the two cars behind me. They were not happy. Diesel everywhere.
Old Sep 21, 2009 | 08:28 PM
biged681985's Avatar
u might have some trash between the connector tube and injector line. god luck figuring it out
Old Sep 21, 2009 | 09:49 PM
nick b's Avatar
i have replaced the o-rings there was some white gunk on the flare of the line that i did not clean off i will try that this weekend if that dont work then i need new lines?
Old Sep 21, 2009 | 09:52 PM
mysterync's Avatar
Most Likely, If you've tightened over in torque spec your at risk for line failure. I've been through it with customers over and over again, I would clean and recheck. Make sure the tubes are seated good in the injector!
LariatOutlawGirl
Sep 1, 2015 02:15 AM
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
InheritedDiesel
Jun 3, 2015 09:39 PM
ash23k
Dec 30, 2014 08:31 PM
Dec 5, 2014 08:30 AM
