water in fuel light
Old Sep 21, 2009 | 03:00 PM
12.valve.hauler's Avatar
Default water in fuel light
my water in fuel light is on and i cant get it to go off. put fuel stabalizer in and everything ran it almost all the way out a couple of times and put more good fuel and stabalizer in it and it wont go off
Old Sep 21, 2009 | 03:02 PM
2500HeavyDuty's Avatar
did you change or drain the water out of the fuel filter?
Old Sep 21, 2009 | 03:27 PM
havent got that far yet. didnt know if i was gonna have to?
Old Sep 21, 2009 | 03:29 PM
im not familiar with the cummins fuel filter set up, does it have a drain to let the water out of the filter?
Old Sep 21, 2009 | 04:19 PM
yes it does.
Drain fuel out of the filter housing remove the bottom, take filter out and wipe out with a lint free cloth, including the wif sensor. Put back together and take off wire connector, spray with wd-40 and reisntall.
Old Sep 21, 2009 | 06:41 PM
wisconsin redneck's Avatar
when ur takin off the WIF (water in fuel) sensor BE CAREFULL the thing is plastic and likes to break real easy!
Old Sep 22, 2009 | 10:43 AM
thanks guys. do you have to re-prime the system and if so how do yu do that exactly
Old Sep 22, 2009 | 06:50 PM
yeh you do... theres primer bulb... alls you gotta do is push that thingabout 50 times n you should be good... its bellow the filte i think
Old Sep 22, 2009 | 08:14 PM
open the banjo bolt on top of the fuel filter housing. Push the primer (its much easier with a wooden dowel). When fuel starts dribbling out of the open banjo close it. Start trucks.
Old Sep 23, 2009 | 12:08 AM
tower_ofpower's Avatar
the 89 has the sensor that screws into the bottom of the spin on filter... they're brittle and probably not cheap... havent had to price one; dont want to price one even tho in reality the sensor should be "water on wires" sensor... the insulation has pulled away from the body exposing 1/8 inch of wire... it gets wet enough... the WIF light comes on....
