93 cummins Advancing Timing
Old Sep 20, 2009 | 09:18 PM
dieselboy1066's Avatar
Default 93 cummins Advancing Timing
I no how to advace timing just how far i can go to a safe level
Old Sep 21, 2009 | 04:19 PM
RSWORDS's Avatar
Stock everything, About 1/8" on teh factory marks. Maybe a little less if you tow heavy.
Old Sep 21, 2009 | 08:56 PM
Begle1's Avatar
As long as your stock everything, I'd seriously doubt that you could hurt anything.
Advanced timing is going to increase cylinder pressures and put more heat into the piston; it makes a given amount of boost more likely to pop a gasket and it makes a certain EGT more likely to melt a headgasket. If you're only pushing 20 PSI and 1000 degrees in the first place, advanced timing is going to result in severe power loss and acceleration lag before it hurts anything.
Old Sep 21, 2009 | 10:34 PM
tower_ofpower's Avatar
maybe i should back off of my favorite pedal position... WFO; i've got slightly over the 1/8th bump goin, 3ish turns on full fuel and other tweaks... 30ish psi out of the H1C
egt's arent bad... sittin below 600 post turbo on level ground and 700 post on slight; long grades... the hotest i've gotten it was slightly below 900 post... saw it and backed out of the juice and backed it down to 55 goin up the hill; took a little while but it came down
Last edited by tower_ofpower; Sep 21, 2009 at 10:34 PM. Reason: Automerged Doublepost
Old Sep 22, 2009 | 09:29 AM
all i got done is a power pin in a brand new injection pump
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
quiksilver1j
Jul 30, 2015 12:41 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
