no wait to start light
Old Sep 20, 2009 | 07:17 PM
timsgsx's Avatar
Default no wait to start light
no wait to start light on my 95 cummins.... i mean its 70 degrees out but shouldnt it still flash on startup?
Old Sep 20, 2009 | 07:28 PM
12valvetater's Avatar
is the bulb burned out?
Old Sep 20, 2009 | 07:59 PM
timsgsx's Avatar
i hope thats why, whats best way of checking carefully without breaking dash accidently
Old Sep 20, 2009 | 08:55 PM
hmm if you hook up a volt meter somehow to check that circut it would tell you but i have no idea how youd hook it up
Old Sep 20, 2009 | 11:30 PM
Hammer's Avatar
Wait to start means the grid heaters are in use and the temp is below the factory set temp.If the wait to start light is not functional it could mean a issue in the grid heater system or their relays.
Old Sep 20, 2009 | 11:58 PM
tower_ofpower's Avatar
unhook your IAT sensor... the light should come on or flash in the dash. atleast it does with the 89, i'd imagine it would do the same on a 95... to elaborate on what 12valvetater had said, if you get a multi meter, put it on volts and hook it up in parallel (negative lead on a good ground source, and positive lead on the back side of the grid heater), if it is fuctioning you should see source voltage, also as hammer said the system isn;t functional above a specified temp which could mean system is 100% functional; just not required to operate... and yes upon first turning the key on systems check should illuminate the wait to start light. check it out and hope its just the bulb, its alot cheaper than the relays
Old Sep 21, 2009 | 12:33 AM
davo79's Avatar
Eh just gut the grid heater and scrap it unless its like 30 out the truck will start just fine
Old Sep 21, 2009 | 08:14 AM
DieselDanBoy's Avatar
bulbs probably just burned out.
Old Sep 22, 2009 | 08:58 PM
timsgsx's Avatar
how many guys have had bulbs burn?
Old Sep 23, 2009 | 12:04 AM
the bulb is probably a 184... its just a small push in one, it'll probably burn out just as fast, maybe a little slower than this bulb being used in any application... they do go out... dunno how often; but nothing is perfect
