My first upgrade to my cummins
Old Sep 19, 2009 | 08:13 PM
nyredcummins's Avatar
Talking My first upgrade to my cummins
Today i sent my girlfriend with me beloved truck to get my piller pod put in. I had to work so i couldnt be there. upstate diesel performance was the guys i sent my truck to. they did a great job, a clean job, and made my girlfriend feel very comfortable well she waited. Not good news when i got to see what the fuel pressure gauge had to say when they where done so now i have to take it back and get an AirDog 150 put in. I will be telling everyone i know about the job they did and i would hope anyone living NY and wanting to get work done on your truck would look them up there website is upstatedieselperformance.com
Old Sep 19, 2009 | 08:22 PM
dustys24valve's Avatar
How lo was the pressure?
Old Sep 19, 2009 | 08:41 PM
maybe 8 then drops to 1 or 0 the you step on it but i might have a gauge that reads a lil high the gauge goes all the way up to 60 psi
i get about 18 psi of boost is that about norm?
Last edited by nyredcummins; Sep 19, 2009 at 08:41 PM. Reason: Automerged Doublepost
Old Sep 19, 2009 | 10:49 PM
Stock truck should see around 20-23 psi. Its probably about right as the Glow Shift gauges are known to be inaccurate.
Old Sep 19, 2009 | 11:27 PM
He means 20-23 psi of boost...
Old Sep 20, 2009 | 12:33 PM
DeLuzGN's Avatar
[QUOTE=lukesdiesel;397515]Stock truck should see around 20-23 psi. QUOTE]
Really, in a stock '99 truck? Mine will only hit 19 psi in stock form.
Add the boost elbow and more fuel, and it'll go higher of course.
I've always read that the '99 automatics only hit 19 or so, while the newer 01 and 02 autos will get a little higher, like the 20-23 range.
Have I been misinformed? I don't have any boost leaks......
Old Sep 20, 2009 | 08:59 PM
they are talking about fuel pressure not boost my truck runs 18-20 with the hammer down up hill i can get almost 20 pound of boost
Old Sep 21, 2009 | 10:30 AM
01quadcab's Avatar
no they are talking boost. Fuel pressure should be no more than 20psi. But I would not drive the truck till you get the fuel pressure up or your going to be spending a lot of money not on mods.
Old Sep 21, 2009 | 04:03 PM
im waiting for upstate to get back to me when they can get me a airdog 150 and when they can put it in this sucks but its better to spend the money on that instead of a new pump. had saved up some money for down payment on new sled but guess ill have to use it for my truck instead
Old Sep 22, 2009 | 03:54 PM
Wyatt Earp's Avatar
Having 20 psi fuel pressure on a VP44 is really high I would think. 17 or so is about normal high from what I have seen. 15 is good, 13 is acceptable and 11 is boarderline trouble.
Now boost on a '99 depending on fueling mods, the turbo and elevation above sea level is likely topped out around 21 psi. 24 at best.
Get a different turbo set up and maybe play with the gate a bit and you could drive that to 30 - 32 without issue. Add injectors and a programmer and along with your new lift pump could get as much as 40 under the right conditions.
