Do it myself CP3
Old Sep 19, 2009 | 07:37 PM
tdiezel's Avatar
Bomb Do it myself CP3
Ok guys I am thinking about doing my CP3 myself. It doesnt look hard at all and the fella I talked to thats going to put mine in said its pretty straight forward. I just have better things to spend $250 on if I can do it myself. What do you guys think? All help, help, pointers, and advice is GREATLY appreciated!
Old Sep 19, 2009 | 07:52 PM
tower_ofpower's Avatar
https://www.dieselbombers.com/5-9l-c...-yourself.html
whitemore so kindly put this together
Old Sep 19, 2009 | 08:16 PM
tdiezel's Avatar
Oh I bought a new one from Industrial Injeciton. I just need to install it is what I meant by doing it myself.
Old Sep 19, 2009 | 09:23 PM
ahhh gotcha; i did see in the other posts )while looking for that one) that you were contemplating the purchase of an already moded CP3, i just figured you decided to do everything yourself. i dont think it'd be too hard... no timing involved... to my understanding its just a gear driven high pressure pump, disconnect the batteries, unhook the FCA and w/e else needs to be unhooked... look at your new pump to see mounting location and number of mounts... i'm not too familiar with these systems so i cant tell you off the bat where everything is... although i do recommend letting the truck sit for awile before you decide to cut the high pressure line loose... heard horror stories, and i've seen what common rail pressure will do to a hot dog on the safety video's... use water and you have hell of a way to cut up your steak wait a little while until someone comes along that is better suited to answer your question... to me it sounds like just a matter of using common sense and doing things systematically in order... like you've heard... sounds pretty straight forward
Old Sep 19, 2009 | 09:36 PM
tdiezel's Avatar
Great! Thanks for the input. It seems just that easy. Just take off the fuel lines and then unmount. Then remount and put all the lines back together. I will wait and see if someone can point me more in the right direction.
Old Sep 19, 2009 | 10:36 PM
2500HeavyDuty's Avatar
thats what it basically is, theres no alignment to worryabout, just remove all the lines keep it clean, remove the bolts (4 of them im guessing) and pull out the cp3.
use an impact to remove the nut on the gear and puller to pull off the gear and mount it in the other one impact it on. and fclide it back in. the new pump should come with a new o-ring.
$250 isnt much for labor compared to a dmax cp3 replacement which would be 8 hours of labor. but then again you can actually see the cp3 on the cummins without removing anything.
Old Sep 19, 2009 | 11:14 PM
tdiezel's Avatar
Ok Im sure I can do it no problem. Do i need to take the belt off the front of the engine before I take the CP3 off? Then I just attach the gear that is turned by the belt on the new CP3? Is it that simple?
Old Sep 19, 2009 | 11:51 PM
what ever gives you more room to work in, batteries disconnected, belt can come off. the cp3 is gear driven from off the crank.
Old Sep 20, 2009 | 07:20 PM
tdiezel's Avatar
So the gear is held in place some how and just connected to the CP3 which means I can take off the CP3 without having to remove the belt and losing belt tension?
Old Sep 20, 2009 | 09:22 PM
scrappy's Avatar
yes you have to take the belt off, the CP3 is mounted to the back of the gear housing with the shaft extending thru the housing. the gear is held to the tapered shaft on the front side of the housing so the gear has to be pulled off before you can remove the cp3. even with the belt off there isn't alot of room for the puller to pull the gear off.
