HELP! Throttle linkage washer size
Old Sep 18, 2009 | 10:17 PM
ZSkibo's Avatar
Default HELP! Throttle linkage washer size
So you know that little steel washer that sits IN the plastic washer under the throttle assembly? It's removed during the VE spring install...anyway...what size is it??? Is this something I can replace at a hardware store or is it a specific cummins part? I ask because I had to remove it tonight in the driveway as part of a fuel line install (don't ask) and it went falling to the fifth dimension. In the off chance (I hope) that I can't find it tomorrow I'd like to get another so my pump shaft won't leak. Anyone??? I'm not a happy camper at the moment. Hopefully a little coffee and sunlight will locate it tomorrow....
Old Sep 18, 2009 | 10:21 PM
tower_ofpower's Avatar
it wont leak w/o that spacer... an o-ring seal it; not that... how ever, i would still tyr to find it or replace it... if it wasnt there for a reason... it wouldnt be there; good luck
Old Sep 19, 2009 | 10:11 AM
RSWORDS's Avatar
No clue on teh size but you can find the part number in this thread
https://www.dieselbombers.com/5-9l-r...ree-temps.html
12vWoodHauler
Sep 30, 2015 07:58 PM
Lawrence D. Sanders Sr
Jan 23, 2015 12:22 PM
jmerriman17
Nov 16, 2014 02:13 PM
1stgenswap
Nov 3, 2014 09:45 PM
marks86
Oct 23, 2014 03:25 PM
