cab light leaks
Old Sep 18, 2009 | 02:16 AM
biged681985's Avatar
Default cab light leaks
im pretty sure on of my cab lights are leaking. i am thinking bout installing a set of the recon smoke color cab lights. i was wondering if any one has every used recon and knows what quality they are?
Old Sep 18, 2009 | 03:50 AM
turbo20psi's Avatar
I have them on my truck,good quality.No issuses with leaking.
Old Sep 18, 2009 | 01:36 PM
kazairl's Avatar
I have them as well and they are pretty nice. I use a light bead of clear silicone on the gasket and under the screw heads when I put them together and no problems with leaks.
Old Sep 18, 2009 | 02:53 PM
outlaw1_gt's Avatar
i like mine did the same as kasairl with silicone
Old Sep 18, 2009 | 04:32 PM
DeLuzGN's Avatar
Did these cab lights come on your truck from the factory, or are they aftermarket?
I've been wanting to put some of the recon lights on mine, but i don't want leaks since my truck didn't come with them.
Old Sep 18, 2009 | 04:41 PM
outlaw1_gt's Avatar
mine didnt come with cab lights and they dont leak
Old Sep 18, 2009 | 07:15 PM
idk if mine came with them or not. as far as i know they did.
Old Sep 18, 2009 | 09:54 PM
dieseldocter16's Avatar
I had the local dodge dealer install the cab lights on mine. I then swapped them out for a set of smoked Recons. Awesome looks and no leaks.
Old Sep 18, 2009 | 10:30 PM
01trailerpuller's Avatar
I have some smoked lights on my truck with no leaks. Also I installed my cab lights myself with no silicone required.
Old Sep 19, 2009 | 12:19 AM
stkdram55's Avatar
like stated above if you run a small bead of silicone then you should be fine...
greenbomb
Chevy/GMC Duramax 04.5-05 LLY
Feb 18, 2018 07:55 PM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
yams
Dec 7, 2014 12:51 PM
