question
Old Sep 17, 2009 | 05:32 PM
03whitechrome's Avatar
Default question
does anyone know if there is anyone that can chip a 97 cummins.. what else can i do to get more power... i have turbo injectors
Old Sep 17, 2009 | 06:29 PM
wisconsin redneck's Avatar
no you cantthe earliest turck cummins wise you can chip would be the 98.5.... i would put a cold air intake, 5 in straight pipe exhaust, dvs, mack rack plug, water/meth injection... what size turbo and injectors do you have? get bigger injectors
Old Sep 17, 2009 | 06:47 PM
mysterync's Avatar
I'm up in western NC, I've got friends with shop all through NC. Give me a call, I'll be glad to help you get some ideas for the truck, From the free stuff to the expensive stuff we do it all
Old Sep 17, 2009 | 08:40 PM
lodal cummins's Avatar
start with pyrometer and boost guage. put in a #10 or 100 fuel plate then learn how to tune your afc. is it a auto or 5 speed? go easy on the fuel if tranny is stock!!!!!
Old Sep 18, 2009 | 03:06 AM
xzaq103's Avatar
FormerVendor
Whats your setup? Trans?
Old Sep 18, 2009 | 09:46 AM
the truck is my buddys he bought the truck with the bd turbo and it had injectors in it.. the truck has a auto upgraded.. suncoast converter suncoast cutches.. i dont know the size of the injectors but why does the truck stall if he puntches it.. if he sits there and revs the truck its fine but if he puts load on it and then lets off it stalls... thanks alot
Old Sep 18, 2009 | 09:55 AM
tower_ofpower's Avatar
idle could just be abit low, also may be a combination of the trans being upgraded and locked tight and the low idle it's just dragging the truck down... bump up the idle and see where it gets you
Old Sep 18, 2009 | 10:18 AM
mysterync's Avatar
Sounds like it needs some pump adjustments. Idle, GSK and so on, It could be the injector, depending on what size and who made it. I'd say Tower of Power is right on with idle!
Old Sep 18, 2009 | 11:12 AM
94 12valve's Avatar
is it a bd super b or the super b special? ... and I thought all diesels came with injectors in them? sorry I had to
Forks diesel nut
Diesel Engine Conversions
Jul 27, 2015 12:19 PM
torg73
May 11, 2015 03:08 AM
99&91cummins
Mar 4, 2015 01:56 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
