NEED HELP
Old Sep 17, 2009 | 02:12 AM
JRIGS308's Avatar
Default NEED HELP
I HAVE A 94 12 VALVE WITH 200 THOUSAND ON IT ITS STARTED WHITE SMOKING AND STUTTERING OUT AT 2500 RPMS . IT HASNT BEEN DROVE MUCH IN THE LAST COUPLE YEAR IVE TRIED ALL THE BASIC THINGS TO FIX I CHECKED FILTERS, PRE STRAINNER , INJECTORS AND FUEL PRESSURE WHAT ELSE COULD IT BE AND WHAT SHOULD MY FUEL PRESSURE BE
Old Sep 17, 2009 | 07:02 AM
94 12valve's Avatar
did you check your timing? and fill out your sig it helps us help you
stock fuel press 17-22psi at idle and 25-35 at 2500 rpm with no load
Old Sep 17, 2009 | 02:59 PM
12valvetater's Avatar
timing
Old Sep 18, 2009 | 07:31 PM
TwinStackPete379's Avatar
Originally Posted by 12valvetater
timing
x2
