crank shaft position sensor
Old Sep 16, 2009 | 01:13 PM
Gibby's Avatar
Default crank shaft position sensor
So bout 3 weeks ago I was running my truck kinda hard whenever the check engine light popped on and tach was on 0 but truck was still running! Well after drivin 4 bout 5 miles the tach started workin again! Well next day I stoped at the auto store and they ran the codes! P0336 if I remember rite! They reset it and been fine! Last nite I headed out drivin easy and tach went 0 and check engine light came on! Drove it back home and cut it off! Now it won't start! I changed the sensor 2 years ago? Could it b bad already, or have I bumped the wires puttin in a new starter! Also I 4got where the sensor is! Let me know whatcha think! Thanks
Old Sep 16, 2009 | 07:10 PM
turbo20psi's Avatar
Could be a loose connection,I think it is behind the balancer idk.I would think that you have to do a crankcase learn after you do it ( replace it).Someone will chime in here of were it is.
Old Sep 16, 2009 | 08:01 PM
nosparkCummins's Avatar
Its in the rear of the block, back by the starter. you have to remove the starter to replace it. Very simple 20 min job
Old Sep 16, 2009 | 10:02 PM
stkdram55's Avatar
yeah its behind the starter...and mine does this from time to time too...and it has a new sensor in it...and yes it should be 20 min job unless the oring is rusted to the block from 10 years on rust belt driving ask me how i know this...
Old Sep 18, 2009 | 05:47 PM
Gibby's Avatar
well the connection was good, so i took off went an bought a new! 70 bucks from advance auto! put it in and fired rite up and check engine light went off! hopefully it fixes it 4 along time ! thanks 4 the help yall
1997silverado
Sep 7, 2023 06:20 PM
Mr. Walkway
May 11, 2015 10:49 AM
robbyS
Apr 16, 2015 02:22 PM
Moly Squid
Mar 28, 2015 04:26 PM
Jmohr52
Mar 4, 2015 01:18 AM
